Joined: 04 Apr 2008 Posts: 1945 Location: Chicago, IL- US
Posted: Mon Apr 13, 2009 2:14 am Post subject: Need ID on some recent finds... |
Can anyone help ID some of these?
I tried Database Archives, but no luck.
NEC D8155, 8039 & 8041 are from an Epson dot matrix printer.
D765AC is from a HD controller board.
The AMD came from an Intel Overdrive socket but I see no part number!
It was covered with hard EPOXY on top, but I found a way the remove the Epoxy without ruining the chip!
I held the side of a hot soldering iron against the epoxy and it softened enough to scrape off with a single-edged razor blade. It's kind of slow, but it works! Try it.
Thanks. |
Joined: 16 Jun 2003 Posts: 8568 Location: State of Jefferson, USA
Posted: Mon Apr 13, 2009 2:38 am Post subject: |
NEC D8039 and D8041 are microcontrollers (add a 'up' in front of NEC Dxxxx part numbers when searching on datasheetarchive.com as the official numbers are uPD8041 etc)
The AMD part number is printed right above the metal slug (on the black plastic, very hard to read) _________________ ***I Aim to Misbehave.***
Joined: 18 Jan 2006 Posts: 4029 Location: Planet Debs
Posted: Mon Apr 13, 2009 11:22 am Post subject: |
D765C is a floppy disk controller (it used to be THE standard FDC, that most FDC were based on).
The most comprehensive guide available for programming them can be found at:
http://www.ukcpu.net/Programming/Hardware/FDC/floppy.asp _________________ Some cause happiness wherever they go; others, whenever they go.
- Oscar Wilde (1854-1900)
chip68
Joined: 19 Oct 2004 Posts: 989 Location: Central Pennsylvania
Posted: Mon Apr 13, 2009 11:30 am Post subject: |
8155 = 2K RAM, I/O, and timer chip
(Same as Intel 8155)
- CMW |
Elar
Joined: 16 Jul 2003 Posts: 464 Location: Tallinn, Estonia
Posted: Mon Apr 13, 2009 11:59 am Post subject: |
82352 - EISA bus buffer
82358 - EISA bus controller
82288-6 - 80286 bus controller 6MHz |
Posted: Mon Apr 13, 2009 12:54 pm Post subject: |
Thanks everybody!
I'm putting an ID sticker on every new non-cpu I find. |
Posted: Mon Apr 13, 2009 12:58 pm Post subject: |
nice finds john....
im use instead of stickers electronic store of the chips with excel sheet for cpu -non cpus to know what i have....  _________________ Sillicon Addicted |
