blank pentium pro
PostPosted: Sun May 10, 2009 2:59 am    Post subject: blank pentium pro Reply with quote
got this several months ago from ebay.
why is it blank ?
thanks
My vintage CPU collection: www.cpumuseum.com
PostPosted: Sun May 10, 2009 4:22 am    Post subject: Reply with quote
Unfinished fake?
Its a pretty early chip. Oldest known Pentium Pro are from week 41 1995 and this around 10 weeks younger.
My collection: http://www.cpucollection.se :::::: http://www.chipdb.org Photos of chips you never knew existed. Now over 5000 different chips in the database.
el_gecko
PostPosted: Sun May 10, 2009 4:48 am    Post subject: Reply with quote
Cpuswe wrote:
Unfinished fake?
Laughing Laughing Laughing
My microprocessor collection: The Gecko's CPU Library
PostPosted: Sun May 10, 2009 10:37 am    Post subject: Reply with quote
myself wrote:
Unfinished fake?
On the other hand, why remove the logo print?
PostPosted: Sun May 10, 2009 10:53 am    Post subject: Reply with quote
Cpuswe wrote:
myself wrote:
Unfinished fake?
oh.. many reasons... recall a certain member of this forum who removed the logo from a ceramic gold top ES pentium with wire wool. Genius.
PostPosted: Sun May 10, 2009 11:06 am    Post subject: Reply with quote
Not only the logo is missing, but laser markings on top as well. They are harder to remove...
I think it is just an empty package.
Register on x86-guide.com to manage and share your collection on-line !
Need to find a x86 ? Go to http://www.x86-guide.com ! Over 4000 cpus listed !
PostPosted: Sun May 10, 2009 11:18 am    Post subject: Reply with quote
test it on some modo.....if even not heat its empty for sure...maybe its just for show-purposes on some intel event Razz
maybe is an attempt to fake it...
who knows....
Sillicon Addicted
Windmiller
PostPosted: Sun May 10, 2009 11:40 am    Post subject: Reply with quote
Very interesting!! I think this is a special PPro sample.
100% of the blank Pentium Pro's I have seen have a engraved number in the bottom right hand side of the ceramic that starts with a E. There was one from Europe that started with a different letter than E but still had the markings in the bottom right hand corner
Also all of the very early Pentiums Pro's samples with markings have the same engraving in the bottom right hand side. Here are examples of both.
The blank below is supposed to be one of the first 50 Pentiums Pro's ever made and the Q0755 is the first documented Pentium Pro Qspec.
PostPosted: Sun May 10, 2009 12:00 pm    Post subject: Reply with quote
NIIIICE! Shocked
PostPosted: Sun May 10, 2009 12:06 pm    Post subject: Reply with quote
but this says: AS NOT ES....?
any ideas? im still think isnt sample or something important...
Sillicon Addicted
kc8adu
PostPosted: Thu Nov 05, 2009 10:26 am    Post subject: Reply with quote
might be a thermal sample?
iirc i have one here.
never did anything with it but suspect its judt a package with a resistor inside.
PostPosted: Thu Nov 05, 2009 10:34 am    Post subject: Reply with quote
Do you have a link to the documentation for Q0755?
PostPosted: Thu Nov 05, 2009 7:32 pm    Post subject: Reply with quote
The production date of the blank (Week 43 1995) is the eariest I have seen so far Very Happy
From the Pentium Pro time line i presume they are early 166 or faster Pro samples, as they were produced after production 150s were released.
I have been wondering.. if they were thermal samples.. why would they have a die date code Confused
EDIT >> checking production codes on the base of Pros.. my belief that it is an unmarked 200MHz 256k ES.. so should be fully functional Very Happy
The additional code etched into the top of "Samples" & early ES comes in 2 formats... Exxx-xxxx or 1xxx-xxxx
The codes starting with E only seem to appear on 256k Pros
while the codes starting with 1 appear only on 512k Pros
These codes are likely put on initially.. with the part number & qSpec put on later as n when they are required Shocked
so ur blank most likely would of ended up being a 256k Q0861
and Jacs blank a 512k Q0865
http://neon-wa.x86-guide.com/en/collection.html
Windmiller
PostPosted: Fri Nov 06, 2009 6:35 am    Post subject: Reply with quote
Trying to find it...I will send it to you when I track it down.
