Windmiller
Joined: 24 Jun 2005 Posts: 1589 Location: Chapel Hill, NC
Posted: Thu Jun 04, 2009 7:14 am Post subject: Benefits from Pentium D to C2D to Quad Core |
I need some advice/info from my fellow collectors about current architecture.We are looking at the benefits and whether there will be any with Quad core's over Core 2 Duo's for our next purchase of 50+ desktops.
A majority of our users run SQL 2005 locally, Office 2007 and our real estate software which is a memory hog. So for SQl 2005, Office 2007 and then typical office use would a quad core provide any benefits over a Core 2 Duo? |
Wizzard1
Joined: 05 Nov 2006 Posts: 879 Location: Boston MA USA
Posted: Thu Jun 04, 2009 8:41 am Post subject: |
Quads are far more expensive- The processor I recommend for the greatest bang:buck ratio would be Intel's brand-spankin new E6300, 2.8GHz/1066. This will give quick response, and the high FSB will help programs gain quick access to the large amount of memory. Make sure and equip it with DDR2-1066!!
OR, for spending *double* the amount on a Q8200, you'll get less single-app performance (non-multithreaded apps) but slighty better performance when the user is doing multiple large applications at once.
But for $80/unit, the E6300 is a fantastically good buy. The quads are just too expensive- Save those for the upgrades. |
Posted: Thu Jun 04, 2009 10:38 am Post subject: |
my answer is:
No!!!
for this purpose u want the machines a cheap c2d do the job! _________________ Sillicon Addicted |
Joined: 01 Feb 2003 Posts: 4349 Location: Fairfax, VA USA
Posted: Thu Jun 04, 2009 4:10 pm Post subject: |
If the real estate software is only used for data entry then dual-core should be sufficient. If it's used to run a bunch of reports and, possibly, other time and/or memory consuming tasks, which do a lot of database lookups (not just one lookup every few minutes) then, IMO, it's better to go to quad-core - something like Q6600.
Windmiller
Posted: Fri Jun 05, 2009 11:39 am Post subject: |
| gshv wrote: | If the real estate software is only used for data entry then dual-core should be sufficient. If it's used to run a bunch of reports and, possibly, other time and/or memory consuming tasks, which do a lot of database lookups (not just one lookup every few minutes) then, IMO, it's better to go to quad-core - something like Q6600.
They do run built-in Crystal Reports but what i wasnt sure of is if SQl, Crystal reports would actually utilize more than 2 cores. |
Posted: Fri Jun 05, 2009 1:18 pm Post subject: |
I think the SQL 2005 support quad-core processors. SQL 2005 license doesn't care if the processors are single-core, dual-core or quad-core:
http://www.microsoft.com/Sqlserver/2005/en/us/special-considerations.aspx
The important question is - what is the average load is going to be on those PCs? If they run Crystal Reports once a day, and it takes some minutes to run it, then they don't need quad-core CPUs.
