How to remove glued heatsinks?
Xaar
PostPosted: Thu Nov 05, 2009 12:06 pm    Post subject: How to remove glued heatsinks? Reply with quote
Hello!
I have some ceramic CPUs here where the heatsinks were glued onto the cpu (of course no boxed CPUs Wink). Is it possible to remove those heatsinks? How runs this best without damaging the cpu?
Best regards,
Xaar.
My trade list ( Updated 2009-11-08 )
PostPosted: Thu Nov 05, 2009 12:50 pm    Post subject: Re: How to remove glued heatsinks? Reply with quote
Xaar wrote:
Hello!
Best regards,
Xaar.
Compress the heatsink in a bench vice. It works every time. Look for my posts in thread from years ago.
http://www.cpu-world.com/forum/viewtopic.php?t=3395
Xaar
PostPosted: Thu Nov 05, 2009 12:59 pm    Post subject: Re: How to remove glued heatsinks? Reply with quote
Ah, thank you for that tutorial Very Happy That should really do it in most cases Smile
Best regards, Xaar.
smithy
PostPosted: Thu Nov 05, 2009 5:16 pm    Post subject: Reply with quote
Good tip Jac...I've got a few to remove, but hadn't got around to it as it didn't seem "easy"...now it is
PostPosted: Thu Nov 05, 2009 5:29 pm    Post subject: Reply with quote
Yep. Works with any heatsink. The low profile heatsinks can be a bit of a bitch, but they all come off in the end. I remember also removing a couple of those glued on pentium gold top heatsinks... removed the logo, but they were all common types etc.
Windmiller
PostPosted: Thu Nov 05, 2009 6:23 pm    Post subject: Reply with quote
Something else I found recently that has worked really well on the difficult gummy 486 and Socket 4 ceramic Pentium.
Run extremely hot water over the top and then quickly rub with a terricloth or paper towel. I did this 3 times and it turned a gummy looking SX842 into a beautiful chip. I had tried all kinds of chemicals that didnt work.
PostPosted: Thu Nov 05, 2009 7:32 pm    Post subject: Reply with quote
Has anyone tried good old liquid laundry detergent or "Mr. Clean" cleaner?
Both dissolve grease and oil. Wink
My collection list (growing) http://johnorun.x86-guide.com/en/collection.html
PostPosted: Thu Nov 05, 2009 7:51 pm    Post subject: Reply with quote
I have an overwhelming urge to post the UZI pic again, surely it will take the heatsink off.
***I Aim to Misbehave.***
PostPosted: Thu Nov 05, 2009 7:57 pm    Post subject: Reply with quote
Laughing Laughing Laughing Laughing
