aguilera2000 Guest
Posted: Mon Nov 23, 2009 8:56 pm Post subject: question on pentium 4 640 |
Hi, i just got a replacement for my cpu. it is a pentium 4 640 and i have a question and hope someone here has the answer for it...
Why do i see 2 CPU's under hardware profiles, the 2 are the same pentium 4 3.20... and even Speedfan shows 2 bars of CPU usage. i know this is a single core cpu so then why does it show twice???
thank you.  |
aguilera2000 Guest
Posted: Mon Nov 23, 2009 8:59 pm Post subject: one more |
| one more question... what is the best temperature RUN this CPU? |
nessus550
Joined: 26 Sep 2008 Posts: 201 Location: Barcelona, Spain
Posted: Mon Nov 23, 2009 9:39 pm Post subject: |
Your Pentium 4 supports HyperThreading, the system see it as if you have 2 CPUs.
Regards |
aguilera2000 Guest
Posted: Mon Nov 23, 2009 9:47 pm Post subject: nessus550 thanks. |
is that good or bad? and is 40c a good running temperature for this CPU? hoter or cooler?
thank you...  |
nessus550
Posted: Mon Nov 23, 2009 9:53 pm Post subject: |
Is a good thing, HyperThreading makes system usage more smooth.
40º is a very good temperature for a Pentium 4 640, you have your P4 very well cooled.
Regards |
