Windmiller
Joined: 24 Jun 2005 Posts: 1589 Location: Chapel Hill, NC
Posted: Tue Nov 24, 2009 4:24 pm Post subject: Heatgun or alternative suggestions |
My heatgun died and I have alot of GPU and CPU to desolder over the holidays and wanted to get some suggestions on what device to buy.
Would a heatgun with variable settings be the best bet?
Thanks for any suggestions  |
Posted: Tue Nov 24, 2009 4:58 pm Post subject: |
I'm pretty ready to bet CPUShack would recommend a good old M2A1-7 flame thrower
g0b _________________ Life is a long lesson in humility |
smithy
Joined: 27 Apr 2008 Posts: 1041 Location: Sydney, Australia
| I use a Makita with variable heat setting and 2 speed fan and it works well |
Joined: 16 Jun 2003 Posts: 7401 Location: State of Jefferson, USA
Posted: Tue Nov 24, 2009 4:59 pm Post subject: |
| g0b wrote: | I'm pretty ready to bet CPUShack would recommend a good old M2A1-7 flame thrower
g0b |
they do work pretty well  _________________ ***I Aim to Misbehave.***
donutty
Posted: Tue Nov 24, 2009 5:06 pm Post subject: |
Propane torch as long as you don't mind the fumes (toasts PCBs hell of a lot easier than a heat gun... ie. they have a habit of setting on fire!)
I have gone through many cheap electric heat guns, and have a Bosch one was second hand from a ex- tool hire auction and it just refuses to fail. |
Posted: Tue Nov 24, 2009 5:34 pm Post subject: |
I also use a propane torch which works well.
Or a turboflame lighter for more precise work.
Windmiller
Posted: Tue Nov 24, 2009 5:35 pm Post subject: |
| donutty wrote: |
Same here, I've gone through a non-name and a Grizzly. I think it's time for some decent. I've heard good things about Milwaukee. |
Posted: Tue Nov 24, 2009 6:03 pm Post subject: |
| Watch out for too much heat from blowtorch if you are not careful. You want cpu, not Burger King. |
Chook
Posted: Tue Nov 24, 2009 10:26 pm Post subject: |
An old electric frying pan also works well. You'll need a small pair of tongs to lift the chips from the boards. _________________ My Tradelist (updated 26 August) |
Joined: 04 Apr 2008 Posts: 1589 Location: Chicago, IL- US
