Charlie T. Guest
Posted: Thu Apr 01, 2010 12:46 pm Post subject: single channel?? |
| I have two unidentical ram sticks rated at 512mb in single channel config.(DDR2-667) that reads 1gb total system memory. what's the difference in performance if you'll select two identical ram modules (512mbx2) in dual channel config that also has 1gb total system memory? Are they the same in terms of performance?? Please help.. thanks. |
Joined: 16 Jun 2003 Posts: 12805 Location: State of Jefferson, USA
Posted: Thu Apr 01, 2010 12:49 pm Post subject: |
performance will be better running dual channel _________________ ***I Aim to Misbehave.***
