slumba
Posted: Tue Apr 06, 2010 10:34 am Post subject: (newbie) is Pentium-60 and 66Mhz CPU considered rare? Value? |
Hi newbie here... is the P60 and 66Mhz CPU considered rare?
I seem to recall that the 60 and 66 were replaced by Intel under their recall after the math unit was not 100% accurate. I assume this means that not many 60s are in the wild these days?
Reason I ask is that I have several of each  |
Chook
Posted: Tue Apr 06, 2010 11:32 am Post subject: |
It depends on what version of P60 and P66. The versions before the recall are rarer than the later versions and the ceramic (non goldtop) versions and the PCPU5V versions are rarer still.
The most recent versions (without the fdiv bug) are the most common and quite easy to obtain.
What is the sspec of your ones? eg SX948, SX828? _________________ My Tradelist (not remotely up to date) |
slumba
Posted: Tue Apr 06, 2010 1:32 pm Post subject: |
Of the 60Mhz's I have handy, I have:
SX835
SX948
SX948
SX950
I have two 66Mhz that both say
SX837
(though oddly the number on the bottom gold area does not repeat SX837 but 1 says E 415 and the other E 418) |
Joined: 16 Jun 2003 Posts: 12824 Location: State of Jefferson, USA
slumba
Posted: Tue Apr 06, 2010 1:47 pm Post subject: |
The two 66Mhz SX837's do have (on the top gold plated part) the words
intel(R)
pentium (TM)
P R O C E S S O R
The 60Mhz SX835 does not have P R O C E S S O R on it. |
Posted: Tue Apr 06, 2010 3:40 pm Post subject: |
ok the processor marked ones are the oldest and have the most value (of the ones you have) _________________ ***I Aim to Misbehave.***
