OC DDR2
Post new topic   Reply to topic    CPU-World.com forums Forum Index -> Memory, peripheral and other chips
Regz1014
PostPosted: Fri Nov 26, 2010 1:22 pm    Post subject: OC DDR2 Reply with quote
When a certain mobo says that it can handle 1066mhz DDR2 in OC mode means that you have to tweak the DDR2-800 module until it reaches 1066 OC? Or can you just install a pair of 1066 module right away even when the mobo can only handle up to DDR2-800? Pls help..I'm new to this topic. thanks a lot!
Tekxpert
PostPosted: Fri Jan 28, 2011 8:02 pm    Post subject: Reply with quote
You would have to read the motherboards manual to understand the method used to achive the 1066MHz OC on the ram. Each motherboard vendor can have a different way of achieving this.
What motherboard is this claim made on?
CPU = One of the most ingenious inventions humans have ever configured and assembled.
Post new topic   Reply to topic    CPU-World.com forums Forum Index -> Memory, peripheral and other chips All times are GMT - 5 Hours
