guso
Posted: Thu Apr 19, 2012 4:10 pm Post subject: |
Hello,
my ICs have arrived a few days ago, savely and in perfect shape.
They look even better than on the photos. :-)
Thanks a lot,
Guido |
silice
Posted: Sat Apr 21, 2012 9:03 am Post subject: |
| Hi receive my chips today thanks pascal |
Robev
Joined: 10 Mar 2006 Posts: 1607 Location: New Zealand
Posted: Fri May 04, 2012 11:40 pm Post subject: |
I found this while browsing today
"Teletext data will be considered throughout the rest of this description, but the invention can also be applied for processing all types of videotext or data transmitted by telephone including alphanumeric data of the "Minitel" type or sound data. An appropriate modem will have to be used for signals received by telephone, for example such as the ITT LOTTI device that receives telephone data and outputs ASCII ("American Code for Information Interchange") data. This device may be connected to the television, built into it, or it may be in a modem-emitter box emitting directly to the remote control. It may also be built into the remote control, and the remote control can then act as a television and/or VCR control device. If the control device receives data through the telephone, the control device 6 may advantageously also be telephone, telephone hand set or a cordless telephone. In this case, the data transmitted from the television receiver is displayed on a display device of the telephone, telephone hand set or cordless telephone, and a viewer can selectively control the television receiver from a control device in the telephone, telephone hand set or cordless telephone in accordance with the displayed data. This aspect of the invention may be advantageously incorporated into a picture phone, which is already provided with a video display screen and the associated video display circuitry. "
Here is the link
http://www.freepatentsonline.com/6021185.html _________________ The Older they are the Better they are. |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
