Spencer121 Guest
Posted: Mon Apr 30, 2012 12:18 pm Post subject: Uneven RAM Capacity.. |
| I recently bought an Asus P5G41T-M LX motherboard with DDR3-1333mhz (OC) support. The manual recommends a maximum of 3Gb of RAM if I'll install a 32-bit windows OS, preferably Windows 7 32 bit. Since Win 7 requires a much larger system memory, but requires less than 3Gb, where does the excess memory go? What's the best way of installing a DIMM in this uneven configuration: The smaller capacity in DIMM-A, larger capacity in DIMM-B or vice versa? I'm confused coz there might be some performance issues behind this. Please help.. Thanks to any reply. |
Joined: 02 Jan 2005 Posts: 5456 Location: Slupsk, Poland
Posted: Tue May 08, 2012 3:15 am Post subject: |
You mean bank A and bank B ? Buy minimum two sticks 2 GB each and 32 bit OS will use ~ 3 GB or 64 bit where full ammount will be used.
DDR3 are so cheap and there is no reason to buy 1 GB stick + 2 GB because you can loose dualchannel support. _________________ ABC CPU |
