Glue on CPUs - brown substance
zburget
PostPosted: Mon May 28, 2012 2:23 pm    Post subject: Glue on CPUs - brown substance Reply with quote
Hello,
on some ceramic CPUs I've residues of used glue (bottom of the cooler)
Does anyone know what it is possible to remove it?
I tried gasoline, alcohol, acetone, silicone remover, but nothing works Sad
Thanks for any advice
Zbynek
Robev
PostPosted: Mon May 28, 2012 3:20 pm    Post subject: Reply with quote
Let it soak in methylated spirits for a day or two
zburget
PostPosted: Wed Jun 13, 2012 3:54 pm    Post subject: Reply with quote
Here I encountered a problem that I did not expect - getting Methanol is almost impossible Sad
Everywhere they want special permission to work with poisons for me Sad
It is possible to use a different solvent? If not, I'll have to find someone with this permission...
PostPosted: Wed Jun 13, 2012 7:05 pm    Post subject: Reply with quote
If the residue is tough and bonds strongly to the chip, it is Epoxy cement and only soaking in Methyl alcohol will soften it.
I've never tried using 100% Ethyl (grain) Alcohol and it might be worth a try....if you don't drink most of it first! Rolling Eyes Laughing Laughing icon_drunk
My collection list (growing) http://johnorun.x86-guide.com/en/collection.html
Robev
PostPosted: Wed Jun 13, 2012 7:36 pm    Post subject: Reply with quote
Chuck them in some 100 proof Vodka Laughing Laughing might do the trick Laughing Laughing
Then you could filter out the impurities when done and still get happy Laughing Laughing Laughing
Chook
PostPosted: Wed Jun 13, 2012 8:10 pm    Post subject: Reply with quote
Methylated spirits is ethanol, not methanol. You will need to soak the chip in it for at least one day and it may take several cycles of soaking and scraping to remove all the residue. I've done out several times and it works well on most epoxy glues.
My Tradelist (not remotely up to date)
zburget
PostPosted: Thu Jun 14, 2012 12:55 am    Post subject: Reply with quote
Hmmm - substance that I have on the CPU it is not tough (it will not epoxy). Consistency more like rubber or silicone and it is such a greasy. So I tried silica remover too, unfortunately unsuccessfully.
PostPosted: Thu Jun 14, 2012 1:19 am    Post subject: Reply with quote
I scrape off that rubber kind carefully with a razor edge, then wipe off the remaining residue with some mineral spirits {Naptha).
tlccomp
PostPosted: Thu Jun 14, 2012 8:10 am    Post subject: Reply with quote
More info here http://en.wikipedia.org/wiki/Methylated_spirit
The two most common elements on Earth are oxygen and stupidity.
Chook
PostPosted: Thu Jun 14, 2012 8:44 am    Post subject: Reply with quote
That's the stuff. Mostly ethanol with a bit of methanol to make it undrinkable. It works well on epoxy glue.
For rubber adhesives, have you tried using an eraser on it (after scraping most of it off with a sharp blade first)? That works sometimes.
I had one Pentium 100 that I could not get the adhesive off. It didn't respond to methylated spirits and was seemed to be harder than diamond. I think I eventually admitted defeat and threw the chip in the bin! Another chip I threw out was a P4 that was covered in Artic Silver, the worst of all the heat trasfer pastes to remove. One touch and its embedded in your skin! Horrible stuff.
