Dynatron T459 Low Profile?
ccc
PostPosted: Sun Jun 24, 2012 9:59 am    Post subject: Dynatron T459 Low Profile? Reply with quote
Hi
What you think about Dynatron T459 Low Profile Active Copper LGA1156 Intel Core i3/i5/i7 ?
Can I use it for i7?
PostPosted: Sun Jun 24, 2012 10:39 am    Post subject: Reply with quote
The clue is in the link "Intel Core i3/i5/i7 CPU Cooler"
If you mean can it be used for socket 1155, then yes. Not sure about 1366.
I wouldn't recommend it if you plan to overclock, it looks like a very basic cooler.
OMG, I finally found out what's wrong with my brain:
On the left side, there's nothing right, and on the right side there's nothing left!
ccc
PostPosted: Sun Jun 24, 2012 2:08 pm    Post subject: Reply with quote
Thx, but I mean the cooling.
Here are the technical specifications:
http://www.ebay.com/itm/Dynatron-T459-Intel-LGA-1155-Lower-Profile-CPU-Cooler-Socket-H2-Core-i3-i5-i7-/130627238073
PostPosted: Mon Jun 25, 2012 2:49 pm    Post subject: Reply with quote
I would take it if no other choice. Expect noise and low airflow. Just beware of the TDB : 73W max. That's eliminate lots of i3/i5/i7 models. Should work with 77W TDP cpus, but try at your own risks.
Register on x86-guide.com to manage and share your collection on-line !
Need to find a x86 ? Go to http://www.x86-guide.com ! Over 5000 chips listed !
ccc
PostPosted: Mon Jun 25, 2012 6:38 pm    Post subject: Reply with quote
Heatsink cannot be higher than 75 mm, very good cooling, no noise and I'm ready to pay a little more.
Here are good pictures how it looks inside:
http://www.pcp.ch/Lenovo-ThinkCentre-Edge-71-Small-Form-1578-E1G-1a16203453.htm
ccc
PostPosted: Wed Jun 27, 2012 7:19 pm    Post subject: Reply with quote
Has someone other idea for a heatsink, it can be expensive, but important is very good cooling and really low noise?
PostPosted: Wed Jun 27, 2012 7:28 pm    Post subject: Reply with quote
If you don't need it immediately, the heatsink mentioned in THIS article might be good, and looks like it may not be too far off production.
ccc
PostPosted: Wed Jun 27, 2012 7:40 pm    Post subject: Reply with quote
Thx, but where can I buy it or is it just a future technology?
PostPosted: Wed Jun 27, 2012 7:47 pm    Post subject: Reply with quote
According to the article in the link, it has been licensed to someone, so will be available "soon".
Robev
PostPosted: Wed Jun 27, 2012 7:49 pm    Post subject: Reply with quote
A very interesting article, video and innovative device. In fact I would even goes as far as to say it is revolutionary.
ccc
PostPosted: Sun Oct 28, 2012 7:40 pm    Post subject: Reply with quote
Sounds really good, where can I buy this Sandia heatsink?
