Identifying an AMD K6-2 Chomper vs. Chomper Extended
feipoa
PostPosted: Sun Jul 15, 2012 3:21 pm    Post subject: Identifying an AMD K6-2 Chomper vs. Chomper Extended Reply with quote
From the information provided on wiki, the AMD K6-2 Chomper was available in 233, 266, 300, 333, and 350 MHz speeds. The AMD K6-2 Chomper Extended was available in 266, 300, 333, 350, 366, 380, 400, 427.5, 450, 475, 500, 533, and 550 MHz speeds.
For 266, 300, 333, and 350 MHz CPUs, how can a Chomper vs. Chomper Extended be determined by physical examination?
It has been suggested that the Chomper versions do not remap the 2x to 6x. Has anyone confirmed this to be true? If so, I am looking for such a chip.
Any information provided would be most appreciated.
diodenmann
PostPosted: Sun Jul 15, 2012 4:05 pm    Post subject: Reply with quote
package number 26050 --> Chomper
package number 26351 --> Chomper XT
feipoa
PostPosted: Sun Jul 15, 2012 5:01 pm    Post subject: Reply with quote
Much appreciated. Any idea if all the Chompers support 2x as 2x, or was it only for a certain frequency range which supported 2x as 2x?
PostPosted: Sun Jul 15, 2012 6:42 pm    Post subject: Reply with quote
On my Biostar M5ALA motherboard, the documented 2x jumper setting results in:
2x multiplier if the AMD cpu has cpuid less than 58C (K5, Chomper);
6x multiplier if the AMD cpu has cpuid equal to or greater than 58C (Chomper CXT, Sharptooth).
I suppose that confirms it.
PostPosted: Mon Jul 16, 2012 3:59 am    Post subject: Reply with quote
My experience: 2x multiplier behavior is in
completely agreement with cpuid as Neon said.
feipoa
PostPosted: Mon Jul 16, 2012 12:44 pm    Post subject: Reply with quote
package number 26050 = CPUID 58C or less?
PostPosted: Mon Jul 16, 2012 7:19 pm    Post subject: Reply with quote
Most of the package 26050 have cpuid=580, but I have seen a few exceptions.
All of the cpuid=58C that I have seen use package 26351.
feipoa
PostPosted: Sat Aug 11, 2012 2:13 pm    Post subject: Reply with quote
I have just confirmed by way of testing that the regular AMD Chomper does allow for 2x multipliers (instead of 6x). The CPUID=0580, and 26050 is printed on the package. Thanks to everyone.
