last-name
Posted: Sun Aug 19, 2012 12:05 pm Post subject: It will be possible for ES? |
ES words printed in the VT82C686B the chip.
VIA ESP 6000 removed to the back there may be the ES? |
last-name
Posted: Sun Aug 19, 2012 12:07 pm Post subject: |
| This is also behind printed on the ES. |
Joined: 16 Jun 2003 Posts: 12986 Location: State of Jefferson, USA
Posted: Sun Aug 19, 2012 12:28 pm Post subject: |
The VIA C3 is ES.
The chipset is not, it actually says 'S3' as its the version meant to be paired with the S3 graphics chip _________________ ***I Aim to Misbehave.***
last-name
Posted: Sun Aug 19, 2012 12:46 pm Post subject: |
| CPUShack wrote: | The VIA C3 is ES.
The chipset is not, it actually says 'S3' as its the version meant to be paired with the S3 graphics chip |
I mean the VIA ESP 6000 there may be is the ES? |
Posted: Sun Aug 19, 2012 12:47 pm Post subject: |
It could be, but I have no reason to think it is.
The board etc its on isnt ES _________________ ***I Aim to Misbehave.***
last-name
Posted: Sun Aug 19, 2012 12:55 pm Post subject: |
This position above the ES word is represented in the sample?
I have another piece is not ES. |
Posted: Sun Aug 19, 2012 1:01 pm Post subject: |
look at the picture upside down and you can see its S3  _________________ ***I Aim to Misbehave.***
last-name
Posted: Sun Aug 19, 2012 1:37 pm Post subject: |
| CPUShack wrote: | look at the picture upside down and you can see its S3  |
No, I can confirm that the ES word.
Re-photographed. |
Posted: Sun Aug 19, 2012 1:47 pm Post subject: |
is Marked ES.... finally..... but what is the purpose on A Comercial Product to use Es -early produce Chips?????
Maybe the Marking Not have to Do with Enginering Sample.... _________________ My Cpu Collection: http://www.cpu-galaxy.at/kosmo/cpu%20collection.xlsx |
Posted: Sun Aug 19, 2012 2:48 pm Post subject: |
ah yes much better picture thank you, does look like it says ES _________________ ***I Aim to Misbehave.***
Joined: 08 Nov 2008 Posts: 6468 Location: Perth, West Australia
Posted: Sun Aug 19, 2012 6:53 pm Post subject: Re: It will be possible for ES? |
| last-name wrote: |
extremely unlikely by the date code & voltage on the ESP6000 _________________ There are 10 types of people in this world:
http://neon-wa.x86-guide.com/en/collection.html |
