Seek advice to remove the SUN Ultrasparc lid
PostPosted: Thu Sep 20, 2012 12:37 am    Post subject: Seek advice to remove the SUN Ultrasparc lid Reply with quote
Hi all,
I have some damaged SUN Ultrasparc cpus. I want to remove the lid without damaging the die. Does anyone have any advice?
Thanks all in advance.
mavroxur
PostPosted: Thu Sep 20, 2012 2:13 am    Post subject: Reply with quote
Maybe gently clamp it by it's edges, and heat the *(@# out of it with a heat gun?
View user's profile Send private message [ Hidden ] AIM Address Yahoo Messenger
PostPosted: Thu Sep 20, 2012 2:17 am    Post subject: Reply with quote
I'll give it a try. Hope that I won't crach it.
PostPosted: Thu Sep 20, 2012 2:21 am    Post subject: Reply with quote
I've had some come off clean, and some take half the die with them
Might soak it in a solvent (like xylene) first, loosen the glue
***I Aim to Misbehave.***
PostPosted: Thu Sep 20, 2012 2:38 am    Post subject: Reply with quote
How long will you soak it? Will a week be fit for it?
PostPosted: Thu Sep 20, 2012 2:52 am    Post subject: Reply with quote
should need more then a half hour or so, It evaporates fast so closed container and/or keep an eye on it
PostPosted: Thu Sep 20, 2012 2:56 am    Post subject: Reply with quote
Thank for your advice. will try this method on this weedend.
