dohoon Guest
Posted: Wed Jul 12, 2006 9:48 pm Post subject: P4 Running Temperature |
hello...
i have a 478 P4 2.8 (533MHz/512KB) on a ASUS MOBO. i have three chasis fans and a zalman CPU cooler. when in idle, my cpu (according to ASUS PC Probe and other monitor program) is at around 42-45C and it goes up to 52 degrees. my MOBO stays around 35C. is my CPU running at high temperature? my friend's P4 2.0 runs at around 30C and i thought that my CPU is running at too high of a temp. what should my CPU values be for temp set-up?
thanks! |
Root
Posted: Thu Jul 13, 2006 12:40 am Post subject: |
Don't beleive to motherboard's HM (hardware monitorng)! In many case it can give wrong parameters of system (voltages, temperatures). So use thermocouple or check cooler temperature by finger  _________________ FreeBSD - forever |
Joined: 02 Jan 2005 Posts: 5481 Location: Slupsk, Poland
Posted: Thu Jul 13, 2006 2:07 am Post subject: |
Temperature under 50 is very good. You can be worry from 65 and up. _________________ ABC CPU |
