Intel 80286: Customer Sample or not?
Yes
20%
 20%  [ 1 ]
Probably yes
20%
 20%  [ 1 ]
Probably no
0%
 0%  [ 0 ]
No
20%
 20%  [ 1 ]
I don't know
40%
 40%  [ 2 ]
Total Votes : 5
PostPosted: Fri Mar 05, 2004 12:14 am    Post subject: Intel 80286: Customer Sample or not? Reply with quote
I bought Intel R80286-10 processor with stamped "CS" on the back:
I have Intel R80286 processors with "CS" and other two-letter codes on the back. Their two letter codes are always the same font and size as other markings on the chip. So, do you think it's a customer sample or not?
Genna
PostPosted: Fri Mar 05, 2004 1:20 am    Post subject: Reply with quote
I think I am going to have to say no on this one.
Just as Pentiums that say ES on them arent samples.
***I Aim to Misbehave.***
PostPosted: Fri Mar 05, 2004 1:41 am    Post subject: Reply with quote
I hope the following picture will better show the difference between "maybe CS" and other CS processors:
"CS" on the left processor does not mean "customer sample". "CS" on the right processor seems to be stamped separately from other markings. By the way, both processors are Intel R80286-10.
Genna
fRaSsL
PostPosted: Fri Mar 05, 2004 2:31 am    Post subject: Reply with quote
I think ES is the same as CS? But CS is not used any longer!? I've only ES 286 seen. I traded mine with Karolo Smile
Frank.
The_Mad
PostPosted: Fri Mar 05, 2004 5:21 am    Post subject: Reply with quote
CS = Customer Sample = Items given for free to a customer who plan to buy thousands. Strictly indentical than the commercial one from a technical point of view.
QS = Qualification Sample = The same as CS, but used later.
ES = Engineering Sample = These CPUs are the only engineering sample, i.e intended for debugging purpose only. They are in an early stage of development and not exactly the same than the commercial one from a tech point of view (like a Beta software, they are Beta Hardware).
Currently, Intel processes for a new processor use three generation of engineering sample (A0, A1, A2) and one generation of Qualification Sample before launching.
I have informations to recognize QS from ES, and the different level of ES. I'll publish them soon Wink
Webmaster http://www.x86-secret.com
Borris70
PostPosted: Fri Mar 05, 2004 5:33 am    Post subject: Reply with quote
hi genna,
i own 16 LCC Intel R80186-10.
5 have thin CS like your left one,
3 have thick CS like your right one,
4 have CT (3 thin, 1 thick),
4 are different
so i also think so, it's not a customer sample (if yes, i would be happy Very Happy
best regards, borris
best regards borris
++ cpu-sammlung.de ++
PostPosted: Fri Mar 05, 2004 10:09 am    Post subject: Reply with quote
Can you post a picture of a processor with thick "CT" letters, or send me a picture of it and I'll post it? On another note - do you want to destroy your "CT" processor, and then we can both claim we have "customer samples"? Very Happy
Genna
Borris70
PostPosted: Fri Mar 05, 2004 10:48 am    Post subject: Reply with quote
hmm, i can't find the thick "CT" any more but i found 2 others with "BY" and "CC". BY is older than CC is older than CS.
i think, i'll throw "BY" and "CC" away Wink
btw: if someone wants to buy ulta-rare R80286-12 Customer Samples ("CS"-marked), please contact me Rolling Eyes
borris
best regards borris
PostPosted: Fri Mar 05, 2004 9:11 pm    Post subject: Reply with quote
Oh well, what a dissapointment... No customer sample for me Smile
Genna
