John S Guest
Posted: Sun Jan 07, 2007 11:53 am Post subject: MS6553 Motherboard |
| I am using a HP Presario 6150,the motherboard is a Microstar MS6553,the CPU is a AMD Athlon 2100+, 266MHz,socket A/462.Can I fit a 2400+ or a 2600+ at the same frequency 266MHz to increase the processing speed.I have the maximum of 1 Gb ram DDR 2100 fitted? |
Joined: 06 Jan 2005 Posts: 1945 Location: Sochaux, France
Posted: Thu Nov 05, 2009 5:50 pm Post subject: Re: MS6553 Motherboard |
| John S wrote: | | I am using a HP Presario 6150,the motherboard is a Microstar MS6553,the CPU is a AMD Athlon 2100+, 266MHz,socket A/462.Can I fit a 2400+ or a 2600+ at the same frequency 266MHz to increase the processing speed.I have the maximum of 1 Gb ram DDR 2100 fitted? |
John, I dont think it would make any difference, as the range of 2000
to 2500 is minimal, better you get another board if you want more speed,
Plus a new Processor etc, otherwise keep what u got ok |
