SL7QB/SL7Q8 Compatible boards list
Goto page 1, 2, 3  Next
Carlos S. M.
PostPosted: Mon Jul 13, 2020 1:25 pm    Post subject: SL7QB/SL7Q8 Compatible boards list Reply with quote
I recently got an SL7QB and decided to test in multiple motherboards, suspringly, i thought it would work on very few boards, but it worked in more boards than i expected, so i wanted to make a thread about compatible boards from my experience and others, if anyone tested in a non listed board, feel free to report in this thread
Working motherboards (boots with the CPU and can boot a 64 bit OS):
Motherboard - Chipset - BIOS
    IBM M71IX - Intel 875P - all
    Asrock P4I945GC - Intel 945GC - BIOS P1.30
    Asrock P4I65G - Intel 865G - BIOS P1.40
    ASUS P4P800 SE - Intel 865PE - BIOS 1012.001 beta
    ASUS P4V8X-MX - VIA P4M800 - BIOS 0701
    ASUS P4V800D-X - VIA PT880 Pro - BIOS 0704
    MSI 865G Neo2-P - Intel 865G - BIOS V3.A
    Gigabyte GA-8IPE1000 - Intel 865PE - BIOS FI
    Gigabyte GA-8S655FX - SiS 655FX - BIOS F3
    Biostar G31-M4 - Intel G31 - Lastet BIOS (modded version)
Failed with SL7QB:
    Intel D865GBF - Intel 865G - BIOS P21
    Intel D865PERFL - Intel 865PE - BIOS ??
    ASUS P4S800 - SiS 648FX - Lastest BIOS
    ASUS P4U800-X - ALi/ULi A800N - Lastest BIOS
    Abit SG-72 - SiS 661FX - Lastest BIOS
    ASUS P4P800 - Intel 865PE - Lastest BIOS
    ASUS P4P800-VM - Intel 865G - Lastest BIOS
    ASUS P4P8X - Intel 865P - Lastest BIOS
    Asrock P4VM890 - VIA P4M890 - BIOS 1.70
Pending to test:
    AsRock P4I65GV (me)
    AsRock P4VM890 (w/ newest bios, me)
LGA 775 boards (using adapter):
Working motherboards:
    Acer Aspire M1610/Verion 261 (Foxconn 672M01-8EKSH) - SiS 672 - Latest IOS
    Acer Aspire M1641 - nForce 630i - ??
    Asrock G41C-GS - Intel G41 - Lastest BIOS
    Asrock 775i65G R2.0 - Intel 865G - Lastest BIOS
    ASUS P5LD2 - Intel 945P - Lastest BIOS
    ASUS P5VD2-MX SE - VIA P4M900 - Lastest BIOS
    ASUS P5VD2-MX - VIA P4M890 - Lastest BIOS
    ASUS P5VD2-VM - VIA P4M900 - Lastest BIOS
    Foxconn 6627MA-RS2H - SiS 662 - Latest BIOS
Failed with SL7QB/SL7Q8:
    Gigabyte GA-8I955X Royal - Intel 955X - Lastest BIOS
    ASUS Maximus Extreme - Intel X38 - Latest BIOS
PostPosted: Mon Jul 13, 2020 2:32 pm    Post subject: Reply with quote
Thank you for this list. I'll be using the Asrock P4I945GC for mine, but it'll be helpful to know what other boards are good.
PostPosted: Mon Jul 13, 2020 3:15 pm    Post subject: Reply with quote
The non working boards, did they not start at all? Or only not the 64-bit OS?
Wasmachineman_NL
PostPosted: Mon Jul 13, 2020 3:50 pm    Post subject: Reply with quote
Strange how the P4P800 vanilla doesn't work, it should be nearly identical to the P4P800SE aside from a worse VRM.
Carlos S. M.
PostPosted: Mon Jul 13, 2020 4:10 pm    Post subject: Reply with quote
All except for the original P4P800 didn't POST at all, the P4P800 was throwing bizarre errors on the BIOS and was unable to start a 64 bit OS (Windows XP x64)
P4P800 SE isn't based on the P4P800, but rather on the later P4P800-E design, it also has a newer BIOS than the regular P4P800
PostPosted: Mon Jul 13, 2020 4:21 pm    Post subject: Reply with quote
Must be a bios thing.
Did you try non-booting boards with regular E0 prescotts?
Wasmachineman_NL
PostPosted: Mon Jul 13, 2020 4:25 pm    Post subject: Reply with quote
But why can I run a SE BIOS on my vanilla P4P800 then?
Carlos S. M.
Yeah, they boot with a SL7PN without issues and have prescott compatible bios
Carlos S. M.
PostPosted: Sat Aug 15, 2020 5:05 pm    Post subject: Reply with quote
Forgot to reply that one, but i never tried since i wasn't sure if there would be issues, especially with a different LAN chip (P4P800 uses 3com 3c940, P4P800 SE uses Marvell 88E8001)
PostPosted: Sat Aug 15, 2020 5:45 pm    Post subject: Reply with quote
If the Asrock P4I65G works, would it be safe to assume the P4I65GV will as well? I'll probably test it at some point, but like to know if there is any point Smile
Carlos S. M.
PostPosted: Sat Aug 15, 2020 6:37 pm    Post subject: Reply with quote
I need to try in mine since i have a P4I65GV as well, but is in storage right now (remains unsteted with the SL7QB as of today)
PostPosted: Sat Aug 15, 2020 7:35 pm    Post subject: Reply with quote
I thought I was OTT with the number of motherboard I have, but I have nowhere near as many of any one socket as some of you guys have Smile Just two shelving units full Smile
Carlos S. M.
PostPosted: Sat Aug 29, 2020 6:52 pm    Post subject: Reply with quote
Added Biostar G31-M4 to the list, needs BIOS mod though
max1024
PostPosted: Thu Sep 03, 2020 3:34 pm    Post subject: Reply with quote
Today I'm just experimenting with G31-M4 LOL
Validation there http://valid.x86.fr/uz9ru6
I need to somehow remove the limitation on the visibility of all 8 GB of RAM. The G31 chipset itself supports 8GB of RAM.
CHips
PostPosted: Sat Sep 05, 2020 3:54 am    Post subject: Reply with quote
Would be fun to make it work with DDR3 using a Socket 478 -> 775 converter...
Or RDRAM if somehow a Socket 423 motherboard supports 64 bits Prescotts, maybe with Bios Mods...
Stelo.xyz Museum (CPU Collection and more)
Page 1 of 3
