IBM P570 Power5 and Power5+ processors
Glory_Cloud
PostPosted: Mon Jun 17, 2013 10:06 pm    Post subject: IBM P570 Power5 and Power5+ processors Reply with quote
I had some IBM 9117 P570 Power5 and Power5+ processor modules
come into my warehouse. I haven't taken a heat sink off yet to see
what they look like. Anyone know what they look like??
( 4 ) IBM 03N5689 1.5Ghz 2-way Power5 processors
( 7 ) IBM 10N7709 1.9Ghz 2-way Power5+processors
( 6 ) IBM 80P5161 1.5Ghz 2-way Power5 processors
( 8 ) IBM 80P5240 1.5Ghz 2-way Power5 processors
The processor modules are on the left of the cases with two per case.
PostPosted: Mon Jun 17, 2013 10:57 pm    Post subject: Reply with quote
taken apart a few
Vlasta
PostPosted: Tue Jun 18, 2013 8:08 am    Post subject: Reply with quote
For sale?
best rgds.
Steve
PostPosted: Tue Jun 18, 2013 12:06 pm    Post subject: Reply with quote
I don't have any more unfortunately
Glory may though
Glory_Cloud
PostPosted: Tue Jun 18, 2013 3:23 pm    Post subject: Reply with quote
How did you get the cage apart to get the heat sink off John?? Smile
PostPosted: Tue Jun 18, 2013 3:49 pm    Post subject: Reply with quote
the processor modules slide out of the big racks, then the 2 halves come apart with several screws (torx IIRC)
Heat to desolder chip from board and heat to remove heatsink
Glory_Cloud
PostPosted: Tue Jun 18, 2013 4:19 pm    Post subject: Reply with quote
OK. I was wondering if I had to take the bottom board
out as I wasn't seeing a way to easily take the side panels
off so I could get to the big heat sink.
PostPosted: Tue Jun 18, 2013 5:09 pm    Post subject: Reply with quote
yah board has to be completely out of the metal enclosure
Glory_Cloud
PostPosted: Wed Jun 19, 2013 9:03 am    Post subject: Reply with quote
It's a big heatsink hiding a nice chip!
PostPosted: Wed Jun 19, 2013 12:17 pm    Post subject: Reply with quote
board has to come out of the case, heatsink should be screwed to bottom of the board
Glory_Cloud
PostPosted: Mon Aug 05, 2013 1:10 pm    Post subject: Reply with quote
I finally have one that I can take apart. The board is free
and out of the metal case but I may still need to use the
heat gun to get the big heatsink to come off the chip.
Hopefully, I will have some pictures of what my Power5
looks like later tonight. Cool
PostPosted: Mon Aug 05, 2013 2:04 pm    Post subject: Reply with quote
heatsink is usually held on by a single screw through a plate on the bottom of the PCB
Then there are one or 2 heatspreaders covering the die, held on with a silicon based glue. These are what need heat to remove.
Glory_Cloud
PostPosted: Mon Aug 05, 2013 8:44 pm    Post subject: Reply with quote
Yeah, the big heat sink came off with just a little heat.
The two "ying and yang" heat spreaders were a bear to get off
but they did finally come loose. Smile
Here is what the IBM Power5 chips that I have look like.
I haven't cleaned it yet but she still looks like a beauty!
I am guessing that it is a 1.9Ghz two-way processor.
PostPosted: Tue Aug 06, 2013 12:01 am    Post subject: Reply with quote
Looks to be POWER5 rather then POWER5+ (die sizes are diff)
only speed you can know is that of the module (using the part number on the metal casing)
Each chip wasnt really rated for a particular speed, only a max, and slapped into any module less then or equal to that
PostPosted: Tue Aug 06, 2013 12:31 am    Post subject: Reply with quote
Nice, if you plan to sell one of these 1 way Power5 I'm in for one
I will be away for 10 days and I can reply only when I will return
