How do you clean your CPUs?
ahia123
PostPosted: Fri Mar 17, 2006 9:02 am    Post subject: How do you clean your CPUs? Reply with quote
I'm wondering what is the best way of cleaning CPUs. I'm using aceton, anybody experienced any negative effect of this? Is there a better way of cleaning the CPUs?
Bjørn
PostPosted: Fri Mar 17, 2006 9:16 am    Post subject: Reply with quote
Hi Bjorn,
I saw many topics like that but no problem to say again : extract benzine is what I always and only use Wink
PostPosted: Fri Mar 17, 2006 10:15 am    Post subject: Reply with quote
Old beer.
no .. only joking... I used MEK* ( Methyl Ethyl Ketone ), that takes off most of the pen marks, writing, grease, glue residue etc. For some sticky labels I use a piece of plastic and gently take most of the label off, then use the solvent to remove the residue.
A good lint free cloth is also good.
* its nasty, and I have a workshop environment to handle it in. So only use this if you have both sides of your brain correctly wired. Not that I do, but I think it is icon_crazy
you could of course BOIL your cpu. Wink
PostPosted: Fri Mar 17, 2006 10:16 am    Post subject: Reply with quote
Hmmm how much cost 0,5 l of Methyl Ethyl Ketone ? Benzine cost 1 euro.
PostPosted: Fri Mar 17, 2006 10:20 am    Post subject: Reply with quote
yeah good point. I think its expensive, and also hard to find in large qty.
BUT.. it is used as the main solvent in plastic plumbing. They dont call it MEK, it just called a plastic pipe cleaner, or De-greaser. You use it to wipe the grease from the plastic pipe then apply the pipe cement ( glue ). If you look on the small print of the label I bet it will say MEK Wink Then it is cheap.
wepwawet
PostPosted: Fri Mar 17, 2006 11:35 am    Post subject: Reply with quote
besides fluids ceramic chips can be cleaned with some kind of rubber as well
PostPosted: Fri Mar 17, 2006 12:27 pm    Post subject: Reply with quote
Embarassed when I was like 6 ( some say I still am Wink ) I used to think a rubber was magic, and when you rubbed pencil markings and also those pen "rubbers" that actually removed the paper a bit, that the removed writing went into the rubber. - which it does technically .. hehe
wepwawet
PostPosted: Fri Mar 17, 2006 12:38 pm    Post subject: Reply with quote
hehe, but you can't rub a 4004 into the rubber:-)
You may use the photos I have posted here under CC BY-NC-SA license.
el_gecko
PostPosted: Fri Mar 17, 2006 12:54 pm    Post subject: Reply with quote
...you can also boil them icon_dance
lol ^^
My microprocessor collection: The Gecko's CPU Library
wepwawet
PostPosted: Fri Mar 17, 2006 1:36 pm    Post subject: Reply with quote
what about a dogs tongue.
bulldogs for 68000,
huskies for 8080
and chihuahuas for 4004.
lol
to be serious, i have a gold cleaning set for jewellry.
i did a test last year: i put a rusty chip in for one day, later i could rub off the rust from the gold lid with my fingernails.
the suspendend thing was: will the chip get rusty again and maybe faster then before?
answer: no, it looks still as pretty as last year.
so this is my preferred method for my rusty chips.
i use acetone ans benzine as well for other purposes.
cheers, michael
Hippo
PostPosted: Fri Mar 17, 2006 2:22 pm    Post subject: Reply with quote
There are three things I use for cleaning CPU's
1. IPA Solvent (Isopropol Alcohol I think). Works great for removing most gunk.
2. A small PCB brush for removing dust
3. A Homemade scraping tool, made from a flexible piece of perspex wedged into a machine file handle. This is great for removing stickers and heavier gunk without ruining your nails/cpu
CPU-Me! Hippo's Collection Online
PostPosted: Fri Mar 17, 2006 2:42 pm    Post subject: Reply with quote
I've got some new tools for cleaning CPUs.
1) A Stanley knife
2) An electric sander
and if they fail, I always have:
3) A kettle Smile
Then of course, there's the universal toolkit, good for all those small tasks:
4) A hammer (in this case, a 4lb sledgehammer!)
Once I have used these tools, I never expect to have another problem with the chips Smile
Beleive it or not, I have seen a number of chips that looked like they had been treated with all of the above tools!
wepwawet
PostPosted: Fri Mar 17, 2006 2:58 pm    Post subject: Reply with quote
when did i show you my collection???
lol
PostPosted: Fri Mar 17, 2006 3:05 pm    Post subject: Reply with quote
You didn't have to show me - I just waited til you were at work and picked the locks. Hey, how do you think I know about these universal toolkits? LOL
wepwawet
PostPosted: Fri Mar 17, 2006 3:16 pm    Post subject: Reply with quote
shit. she was on m shelf.
i'm blamed,
totally blamed.
