Unzlbunzl
Joined: 30 Jan 2007 Posts: 468 Location: Graz, Austria
Posted: Thu Jan 24, 2008 5:34 pm Post subject: Athlon K7 - working or not quiz |
got nothing to do....but testing cpu
so here are some pics of some of my S462 K7s - have a look and guess which ones successfully managed to boot into WIN98 and which ones didn't.
winner gets a dead athlon1000 if he pays the shipping...lol
i would call them
a1 b1
to
a9 b9
red dots hide my testing results |
iguana
Joined: 24 Apr 2007 Posts: 2456 Location: Ottawa, Canada
Posted: Fri Jan 25, 2008 3:57 am Post subject: |
I'm a bit pessimistic...
O - OK
X - DEAD
XO
XX
XX
OX
OX
XX
XX
XX
XO |
Heartbreak one
Joined: 19 Dec 2007 Posts: 130 Location: Mandal, Norway
Posted: Fri Jan 25, 2008 9:48 am Post subject: |
I'll use the same O and X system as Qwerty:
OO
OX
XX
OX
OX
XX
XX
XX
XO
I were judging them by basic condition look so I am not sure if it is correct or not
P.S.
If I win, please don't send me a dead Athlon  |
faber
Joined: 18 Dec 2006 Posts: 315 Location: Poznan, Poland
Posted: Fri Jan 25, 2008 12:34 pm Post subject: |
XO
OX
OX
OX
XO
XX
XX
OX
XO
P.S.
I also don't want to get dead Athlon  |
Borris70
Posted: Fri Jan 25, 2008 5:14 pm Post subject: |
i'm more optimistic:
OO
OX
OO
OO
OX
OO
OO
XO
XO
no dead athlon please  _________________ best regards borris
++ cpu-sammlung.de ++
Windmiller
Joined: 24 Jun 2005 Posts: 1716 Location: Chapel Hill, NC
Posted: Fri Jan 25, 2008 5:42 pm Post subject: |
OO
XX
OX
OX
XO
XO
OO
XO
XO |
Heartbreak one
Posted: Sat Jan 26, 2008 6:45 am Post subject: |
| Who has the best guessing? |
iguana
Unzlbunzl
Posted: Sat Jan 26, 2008 12:10 pm Post subject: |
| at the moment marcin is leader...only one with 50+% correct i think |
Heartbreak one
Posted: Sat Jan 26, 2008 12:29 pm Post subject: |
This is going to be very tough... xD
Is it allowed to guess two times? |
Unzlbunzl
Posted: Sun Jan 27, 2008 7:54 pm Post subject: |
the correct answer would have been
XX
OO
XX
OO
XX
OO
XX
OO
XX
the Athlon 1400 in the last row is working at up to 1200Mhz, the Duron in the last row is posting, not booting.
anybody has any idea which parts of the die don't affect the function if damaged?
Marcin is the winner with 10/16 (last row excluded) |
Posted: Mon Jan 28, 2008 5:37 am Post subject: |
| Unzlbunzl wrote: | | anybody has any idea which parts of the die don't affect the function if damaged? |
All parts of the die are important.
Damaged edges of the silicon crystal will not affect the circuits on the die directly. The circuits lie at the bottom of the die between SI crystal and the chip's base.
Only if the die has cracks the circuits are destroyed.
If the die's edges are damaged the CPU will work for some time, but then will fail due to overheating.
The damaged edges don't have the contact with the headspreader! The circuits beneath such areas will overheat (and/or be destroyed) after a very short period of time.
The BIOS will not prevent the CPU from overheating because the average temperature of the die stays normal.
The booting of Windows 98 isn't a big challenge for a damaged chip.
If you install one of your CPUs with damaged die and run Prime95 on it, it will not survive the test  |
Unzlbunzl
Posted: Mon Jan 28, 2008 10:01 am Post subject: |
tried one of them with my xp on scsi and prime(max temperature), tested for about half an hour without errors. temperature rising from 47 to 52°C and staying constant for 20min. to me the chip seems to be in a quite good (technical) condition. are there visible structures on the back of the die of those flip-chip packages (like on the dies under a lid)? or will there just be lots of tiny solder spots?(notice the golden spots on the right of the duron, intended to connect the additional cache of the athlon, i think).
does anybody have a pic of the classic athlon with descriptions for the areas? (couldnt find any on google) - getting on topic now.
noticed CPUID 0630 (A0) for AKBA isn't on the "Stepping codes of AMD K7 microprocessors" page |
