Cutabove
Posted: Sat Sep 12, 2009 7:36 am Post subject: |
| Quote: | | My advice would be to ask 'where are the oldest boards/' because it looks like that stuff has accumulated over several years. That probably means the oldest (and best) stuff is at the bottom! |
| Quote: | | i would suggest taking these two screwdrivers. |
SCREW THAT!!!! WHAT THE HELL ARE YOU GUYS THINKING?!?!?!? BRING A FRONTEND LOADER AND A TRACTOR TRAILOR!!!!!!!
COOP SAYS "umm excuse me sir,but I brought some help.Can you tell all of these people to please move so I can start loading my boards?........ROFL!"
| Quote: | | Ill bust out with the Ninja outfit and make a stealthy helper |
Let me and chief at them...we'll bust out like mission impossible and have a military helicoptor hauling off the loot before you know it. _________________ Everything that is gold,doesn't always glitter. |
Chook
Posted: Sat Sep 12, 2009 10:24 am Post subject: |
| Neon_WA wrote: | Seeing u dont need to open any cases.. u dont need a philips head, so i would suggest taking these two screwdrivers.
a thin shaft flat with narrow handle (to remove Dips, levering one end slightly then working the screwdriver completely under)
a wide bladed flat with fat handle ( to lever PGA chips from the board, prising one edge at a time a little more, by turning the screwdriver)
How about using a PGA chip remover? (there's one in 486 overdrive kits) _________________ General failure reading disk in drive A
Who's General Failure and why is he reading my disk? |
Posted: Sat Sep 12, 2009 11:23 am Post subject: |
| Chook wrote: | | Neon_WA wrote: | Seeing u dont need to open any cases.. u dont need a philips head, so i would suggest taking these two screwdrivers.
How about using a PGA chip remover? (there's one in 486 overdrive kits) |
The PGA chip removers do make the job a lot easier. I have found that using one reduces the risk of damage toa chip to zero  _________________ My graphics card database can be found at http://www.gpuzoo.com.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
