Glory_Cloud
Posted: Sat Aug 21, 2010 8:56 am Post subject: |
That's a beauty! What solvent do you prefer when cleaning up
chips? I just use denatured alcohol. Is there anything better to use.
This chip really cleaned up nicely! |
Chiefish
Posted: Sat Aug 21, 2010 10:04 am Post subject: |
I will usually just use alcohol, unless the chip has the black scratches from solder and other metals scraping against it, then I use Tarn-x silver and gold polish. Works great on the ceramic and dissolves the metal residues as well as polishing up the gold surfaces.
It also doesnt seem to affect the ink that was used on these older chips. Also works real well on getting off the gummy remains of old ESD foam that seems to melt over time and adhere to the legs of chips as well. _________________ "The only reason for time is so that everything doesn't happen at once." A.E. |
Posted: Sat Aug 21, 2010 12:12 pm Post subject: |
| Chiefish wrote: | I will usually just use alcohol, unless the chip has the black scratches from solder and other metals scraping against it, then I use Tarn-x silver and gold polish. Works great on the ceramic and dissolves the metal residues as well as polishing up the gold surfaces.
It also doesnt seem to affect the ink that was used on these older chips. Also works real well on getting off the gummy remains of old ESD foam that seems to melt over time and adhere to the legs of chips as well. |
what stores sell this?
can I get it at like Wal-mart? _________________ New for 2025! The CPU Shack has a co-processor!
Chiefish
Posted: Sat Aug 21, 2010 12:15 pm Post subject: |
I am pretty sure just about anywhere, Shop Rite Wallyworld--AKA Walmart, A&P, Kmart, ect.
Grocery store is where I pick mine up at. _________________ "The only reason for time is so that everything doesn't happen at once." A.E. |
Glory_Cloud
Posted: Sat Aug 21, 2010 12:23 pm Post subject: |
I get my denatured alcohol at Home Depot.
Kleen-Strip S-L-X.  |
smithy
Joined: 27 Apr 2008 Posts: 2906 Location: Sydney, Australia
Posted: Sat Aug 21, 2010 7:15 pm Post subject: |
Well done...great find! _________________ My former Intel collection:
www.smithschips.com.au |
