? difference between HT P4's SL7KK and SL7J6
Goto page Previous  1, 2
midsouthduckhunter
PostPosted: Thu Feb 11, 2010 5:15 pm    Post subject: Reply with quote
I have a little Arctic Silver left so I'll use it. I took some pics to write an article, so I'll post them when if I get this thing going.
I'll be really surprised if the 3.6 doesn't run. BTW, how did you know the 3.8 was overheating before starting? There might be something there.
xrror
PostPosted: Fri Feb 12, 2010 4:05 am    Post subject: Reply with quote
Well the first cold boot it ran for about 10 seconds before it just shut off. You had to wait at least 10min or it would just hang instantly on startup. Or... you just cheat some and empty a can of "air duster" into the heatsink (upside down) for some liquid excitement.
But I'm not sure this applies to your situation, since the Profile would at least attempt to POST once.. it'd beep at least.
But still... the 571 can't be that different from the 3.0Ghz P4 you had. It just bugs me... I mean it should at least do something but that's just me. It really could be incompatible but... after my experience with the 3.8Ghz (that chip basically was it's own stepping) working in the craptacular i915board in the profile. I dunno. It depends on just how much you want to try to get it to work. It might be a lost cause.. but.. lol I'm bad at not letting things go when I should.
Either I brick a board eventually with horrible bios kludges - and see, all that means to me is the soldering iron if they didn't put a socketed bios chip (except the evil Intel Flash TSOP package... I'm not that good with a soldering iron) or it finally burns something. So ehhh, maybe I'm not the one you should be taking advise from Laughing
midsouthduckhunter
PostPosted: Mon Feb 15, 2010 2:04 pm    Post subject: Reply with quote
OK, I'm pretty sure I blew up the mobo.
While I was waiting for the new 560 3.6 ghz chip to arrive, I had the original 530 in and testing the new Dynatron P555 cooler. Well, the CPU was running a little hot around 58C, but I was waiting for the Arctic Silver to start working. Sometimes the CPU would go to 70C but the fan would ramp up and it would come back down.
After a few hours of 10-70% CPU usage, I turned the PC off. Later I needed to do something on the PC and TRIED to turn it on. I got nothing. The same black screen as I got when I put the 571 in. I waited until the next day, and the same thing.
The following day, the 560 arrived so I was going to put that in. Upon removing the cooler, it was evident from the thermal grease pattern, I had not secured the cooler evenly and that led to the high CPU temps. Not to worry, I put the 560 in, secured the cooler, and promptly pulled it back off to check the grease pattern. It was all good, so I bolted it back down and powered it up. Nothing happened again. Black screen; no beep, no HD access just a little fan noise.
WTF else could I have done besides fry the 530? And, if I did fry it, why the heck did it keep working and then die when I tried to boot again? My easy peasy CPU swap just blew up in my face. I guess I could get a replacement mobo, but I think I should cut my losses at this point...except I want to fix it and find out what happend?
As always, suggestions and comments are appreciated.
PostPosted: Mon Feb 15, 2010 3:29 pm    Post subject: Reply with quote
I will never drop my kids at your place for babysitting Wink
Have you tried resetting the cmos? Unplugging the psu for a few minutes?
This sucks, I think you are ready for a core2 duo upgrade...
xrror
PostPosted: Mon Feb 15, 2010 3:46 pm    Post subject: Reply with quote
Ouch, at least the fans spin up though. All I can think of is possibly a cpu socket "pin/pad" whatever they're called got bent in the socket. Or the PSU went south. But the fact that the fans at least spin... well at least the board is passing the power-on signal.
But no, unless the cpu was totally electrically incompatible (I seriously doubt that) or the seller of your 571 sold you a "widowmaker" (part that kills other parts). But that's unlikely too. P4's are actually pretty hard to thermal kill, since the thermal throttling is on die. And 70C isn't anything... lol that Gateway profile I told you about, it hit over 90C before it shut off. Multiple times. Which is horrible, but no heat death. I think in normal operation it ran about 75C load in that board, not good, but nothing smoked so you should be alright as far a cpu's go.
I'm trying to find some more info on the PTGD1-LA. I'm looking for some "stupid pet trick" to truely tell if the motherboard in permanent coma. For instance, my unofficial and unscientific test for Intel and Intel rebranded OEM boards is if when you pull the BIOS config jumper OFF completely (normally it's set to "normal" or "config") if the board doesn't start thrashing the floppy drive trying to recovery flash, it probably really is DOA.
But since your board is an "OEM'ed" Asus, which... what i'm trying to find out is if HP used Award, AMI, Phoenix or whatever it is if there is some true litmus test that the board is totally hosed.
Don't give up yet. But... yea that really sucks. Worst case, I guess keep en eye out for a cheap 775 board that's halfway configurable (I dunno, AsRock used to have some). If anything it'd be a fun test bench for the chip collection you're accumulating.
But I'm going to keep looking for more PTGD1-LA info. It's unfortunate that people don't tinker with the oem'ed boards more, or at least post info about them... that'd be a fun website to build. OEMboardAbuse.org or something. Anyways yea I'll keep looking.
midsouthduckhunter
PostPosted: Tue Feb 16, 2010 9:05 am    Post subject: Reply with quote
Guest, you know I could keep the kids warm...but the contact cleaner needed to remove the Arctic Silver is prolly not good on their skin.
I did try to reset the CMOS by moving the jumper between 1-2 , 2-3 and then back to 1-2 or whatever the sequence. I did that after I put the 571 in at first. I removed the power when I replaced the chips, so the PSU was always unplugged for a few minutes.
I found this link:
http://www.fixya.com/support/t506228-asus_motherbaord_ptgd1_la
but I can't follow it here at the office. There might not be anything there, but xrror check it out. I am searching for another PTGD1-LA mobo, but they are all priced about $90 which is too much.
PostPosted: Tue Feb 16, 2010 10:33 am    Post subject: Reply with quote
As long as kids are cozy... Smile
The link suggestiosn are:
- check capacitors fro swollen ones
- check all power plugs are right fastened
- remove hdd, may be defective and triggering black screen
I add, remove everything and see if it starts with one stick of ram etc... you know the drill.
There is direct link to an intel solution but it's just OS related startup issues, doesn't apply to your case.
Basic stuff.
xrror
PostPosted: Sat Feb 27, 2010 9:52 pm    Post subject: Reply with quote
Ugh, so I can't find much. Seems most people just throw the entire computer out d'oh!
So that isn't much of an option. The closest I got for the the equivalent Asus based non-OEM was the Asus P5GD1 - but even it doesn't list core2 support so that's not really a particularly attractive option either.
PostPosted: Sun Feb 28, 2010 10:19 pm    Post subject: Reply with quote
edit add: man, I really hope I didn't accidentally lead you down the path to killing your board. I re-read the thread today and now I'm feeling bad about it. Sad
Page 2 of 2
