Please help indentify this AMD CPU
Goto page Previous  1, 2, 3  Next
Wannial
PostPosted: Mon Nov 29, 2010 12:48 pm    Post subject: Reply with quote
My opterons arrived to, I'm just not realy satisfied with the state they arrived in.
Covered in cooling paste, and the other cpu doesn't seem to be in a 100% good condition either. (right cpu, left lower corner of the center chips)
Let it know asap if I had a closer look.
Hope to test it soon, and I hope it wasn't a waste of money to buy a dual G34 socket mother board...
PostPosted: Mon Nov 29, 2010 1:26 pm    Post subject: Reply with quote
Before you pull them into sockets clean by alcohol or "extracted benzine". Thermal paste cann't damage CPU in this case only you can only stain sticks in socket and then will be much harder to clean.
Wannial
PostPosted: Mon Nov 29, 2010 1:36 pm    Post subject: Reply with quote
I already got the paste of, but the connectors don't look great.
Will post pic asap (this weekend)
p.s. excuses my grammar, i'm Dutch Smile
PostPosted: Mon Nov 29, 2010 2:45 pm    Post subject: Reply with quote
If you used good chemical then there is now worry about.
PostPosted: Mon Nov 29, 2010 6:58 pm    Post subject: Reply with quote
and about the other prblem
On the right cpu on the picture it seems the chip most left down in the core is broken.
I don't have them in reech, i'll check it out and take some high res pics so I can check exactly.
PostPosted: Mon Nov 29, 2010 7:26 pm    Post subject: Reply with quote
It looks that one of the capacitors is mis-aligned.
This may be no problem if it is only slightly mis-aligned, and not damaged. A higher resolution picture would help to determine if there is any damage.
Wannial
PostPosted: Tue Nov 30, 2010 10:23 am    Post subject: Reply with quote
Seems I wasn't logged in on my last responce.
I've got this picture
Wannial
PostPosted: Wed Dec 01, 2010 7:18 pm    Post subject: Reply with quote
Anyone? Smile
PostPosted: Wed Dec 01, 2010 8:20 pm    Post subject: Reply with quote
Those are decoupling caps, run it, its likely it will still work fine.
Wannial
PostPosted: Sun Dec 05, 2010 7:25 pm    Post subject: Reply with quote
I just checked it out, it's realy broken, clean of.
Litle hasitating of using the cpu just like that.
Might solder it back with some realy fine tools
PostPosted: Mon Dec 06, 2010 12:55 am    Post subject: Reply with quote
Using the CPU without it will not hurt it, it will either run fine, be unstable under high load, or not run.
Wannial
PostPosted: Mon Dec 06, 2010 5:29 pm    Post subject: Reply with quote
Oke, that gives me a lil bit more confidence on placing it on my brand spanking new asus kgpe-d16
let you know when it arrives and when i've tested it
Wannial
PostPosted: Sat Dec 18, 2010 7:03 am    Post subject: Reply with quote
Oke this is kinda awkward, both of the cpu's work, but not together, if I place both of them on my asus kgpe-d16 i won't get a post or anything, but if I just place one of them it works..
Wannial
PostPosted: Sat Dec 18, 2010 9:49 am    Post subject: Reply with quote
is it posible that the broken part on the cpu is involved in this?
I don't realy know what those things do..
PostPosted: Sat Dec 18, 2010 1:45 pm    Post subject: Reply with quote
Try one at a time, and then use something to stress test them (run under full load)
See if one crashes.
What those do (decoupling capacitors) is decouple any power to ground noise/ripple.
Page 2 of 3
