P2 Overdrive data
Goto page Previous  1, 2, 3, 4  Next
PostPosted: Sat May 14, 2011 8:04 pm    Post subject: Re: P2 Overdrive data Reply with quote
lither wrote:
Neon_WA wrote:
do you have a picture of the under side.. it may help decide
or is there anything written on the heat-sink under the fan?
http://www.cpu-world.com/forum/viewtopic.php?t=11757&start=15
it is completely blank
no die cap.. so "die assembly" will be on the top like a P2 overdrive
just that it is made in ceramic
Cutabove
PostPosted: Mon May 16, 2011 12:20 pm    Post subject: Reply with quote
Hi Neon,
I was going through some chips I had and saw that I had a PII OD also
Here is mine
A PODP66X333 SL2KE v1.0
B 692077-001
C L835A138
D L8272329-0173
E IN6T84201210
Mine came from an IBM AS/400E mainframe
Everything that is gold,doesn't always glitter.
PostPosted: Mon May 16, 2011 5:50 pm    Post subject: Reply with quote
Cutabove you have got some nice chips in the lot Smile
My vintage CPU collection:www.cpumuseum.com
Chinese Forum: http://www.cpumuseum.com/forum
PostPosted: Tue May 17, 2011 4:30 am    Post subject: Reply with quote
Cutabove wrote:
Hi Neon,
Here is mine
data added.. thx for die FPO info Smile
stratmaster
PostPosted: Tue May 17, 2011 10:48 pm    Post subject: Reply with quote
A. PODP66X333 SL2KE V1.0
B. 692077-001
C. L835A141
D. L8272329-0099
E. IN6T84003577
Chook
PostPosted: Wed May 18, 2011 6:56 am    Post subject: Reply with quote
From my NIB:
USN9212633
MM#:816625
Pack Date: 05/25/99
General failure reading disk in drive A
Who's General Failure and why is he reading my disk?
picur10
PostPosted: Sun May 29, 2011 6:26 am    Post subject: Reply with quote
A. PODP66X333 SL2KE V1.1
B:737446-001
E:IN6T92900811 AA 737436-101
sorry, I wouldn't like to remove the heatsink.
PostPosted: Sun May 29, 2011 6:56 am    Post subject: Reply with quote
B:737446-001
can you please post a pic of the bottom... as the numbering is for a SL3EA Confused
picur10
PostPosted: Sun May 29, 2011 7:08 am    Post subject: Reply with quote
damn copy&paste. You're right, it's a SL3EA. I checked all datas, everything is good but sSpec. Embarassed
PostPosted: Sun May 29, 2011 7:10 am    Post subject: Reply with quote
was guessing it was gunna be a typo.. but thought best to check Wink
so yours is from week 29 1999 Smile
PostPosted: Thu Aug 18, 2011 4:16 am    Post subject: Re: P2 Overdrive data Reply with quote
lither wrote:
an overdrive thermal sample
it is ceramic but the HS says it is for overdrive thermal sample
i dont know it should be categoried to PII overdrive thermal sample or pentium pro thermal sample
http://www.chipdb.org/details.php?image_id=7074
had a re-think about this one after the P1 OD mech sample came up without a die cap.
this chip not having a die cap doesn't necessarily make it a P2 OD thermal sample.. it could still be a Pentium Pro thermal sample Confused
lither
PostPosted: Thu Aug 18, 2011 5:34 am    Post subject: Re: P2 Overdrive data Reply with quote
so you get the P24CT mech sample?
congratulation!
PostPosted: Thu Aug 18, 2011 7:14 am    Post subject: Reply with quote
yes & thanks
sorry mate. I was told afterwards that you had planned to bid.
but I knew if it went to auction it would be a lost cause for me
No markings on the top.. just a neoprene block (the "C" Spacer) to act as the pretend heat-sink & fan
Did you notice the 2 extra pins on the bottom?
lither
PostPosted: Thu Aug 18, 2011 7:26 am    Post subject: Reply with quote
the picture is too small , i didnt find that
never mind , if the seller let the auction go on ,the price would be higher than $500+ which is also out of my budget
PostPosted: Mon Sep 05, 2011 9:10 pm    Post subject: Reply with quote
Just wondering where the sSpec SL2K3 came from?
The only reference I can find is a NIB listed on cpu-sammlung.de which I am starting to guess is possibly a typo
Info on this may have been posted on cpu-museum.de/forum but the forum is still dead, so willl send a PM to Borris to please confirm sSpec
Page 2 of 4
