[Failed!]Remove Heatsink from Gold Cap P90, Experiment 1
Goto page Previous  1, 2
Glory_Cloud
PostPosted: Wed Jul 13, 2011 9:41 am    Post subject: Reply with quote
Exact same thing happens when you use a heat gun. Sad
PostPosted: Wed Jul 13, 2011 10:18 am    Post subject: Reply with quote
Concerning this kind of circular mark, I have successfully removed it using a simple rubber!
http://www.x86-guide.net/Xhoba/en/collection.html
PostPosted: Wed Jul 13, 2011 10:45 am    Post subject: Reply with quote
Neon_WA wrote:
let me know what the FPO code is L41????
quite often the print sticks better to silicon glue than it does to the gold surface.
No matter what you do.. in the end it is lucky of the draw
Yes, It is L41
Want List
Trade List(Up-to-date)
PostPosted: Wed Jul 13, 2011 10:48 am    Post subject: Reply with quote
Chook wrote:
That type of glue is one of the worst types. Its very hard to remove it without removing the print and I've never been able to remove all trace of the glue. The circular mark always remains.
The white epoxy type glue is much easier to remove with metho and there is good odds of the print remaining intact.
Yep, the white epoxy glue is better.
I've got few SX957,SX958 with heat sink uses such glue, it is much easier to remove the heat sink without damage the label.
Want List
PostPosted: Wed Jul 13, 2011 10:50 am    Post subject: Reply with quote
I think the label had already stick on the glue. No matter what method you use, the label would not stay on the gold surface
Want List
PostPosted: Wed Jul 13, 2011 10:53 am    Post subject: Reply with quote
I think the glue had kind of chemical reaction with the ceramic. The glue can be easily removed by a rubber, however the color difference is noticeable.
Want List
PostPosted: Wed Jul 13, 2011 12:39 pm    Post subject: Reply with quote
steel wool will remove the pink mark on the ceramic (use a fine kind)
I also have some glass polish (like toothpaste almost) that works well.
PostPosted: Wed Jul 13, 2011 1:37 pm    Post subject: Reply with quote
njfn please provide a picture after cleaning with your method - rubber. Thanks
PostPosted: Wed Jul 13, 2011 2:24 pm    Post subject: Reply with quote
even the rubber could clean some of glue, but the circle is noticeable at all.
I said, the glue could have some chemical reaction with ceramic, therefore there's nothing i can do with it.
If you go to chipdb, you can also see the SX909 has a obvious circle mark on the chip
Want List
max3
PostPosted: Wed Jul 13, 2011 3:37 pm    Post subject: Reply with quote
very nice report.
thanks.
its here.
PostPosted: Wed Jul 13, 2011 6:17 pm    Post subject: Reply with quote
Yes, It is L41
but what is the rest of the FPO number ?
PostPosted: Thu Jul 14, 2011 12:01 am    Post subject: Reply with quote
Yes, It is L41
Sorry,
The FPO number is L4193102-0381
Want List
PostPosted: Fri Jul 15, 2011 12:35 am    Post subject: Reply with quote
It's still a nice chip... Smile
My collection list (growing) http://johnorun.x86-guide.com/en/collection.html
PostPosted: Fri Jul 15, 2011 12:42 am    Post subject: Reply with quote
Yes, it is Smile
Want List
Page 2 of 2
