Posted: Sun Jan 05, 2020 3:49 am Post subject: |
| Mixeur wrote: | I'm using an ATI Radeon 5870. Not so hungry I think, but the powermeter can't lie.
I'm using an old 480W PSU from the P4 era. I think that 12V line is really too weak.
With the 6238, Windows 10 won't install. But now it is installed using the 6128, I will try again tomorow with the 6238 and the other ones I have. |
Old PSU is not efficent. Propably to much loss and like you said weak 12V line. I would check with low power vga.
Windows 7 or 10 need additional drivers for this board ? Seller doesn't seems to provide any. _________________ Visit ABC CPU - Virtual CPU Museum. |
Posted: Sun Jan 05, 2020 4:57 am Post subject: |
Windows 10 doesn't need anything.
I'm currently writing on the system with the ZS200800TCE25 from crazybubba installed. And despite what crazybubba said and what is written on cpu-world identification page, it is not a 12 cores but a 8 cores . And Windows identifies it as a 6128... _________________ Register on x86-guide.net to manage and share your collection on-line !
Joined: 20 Apr 2009 Posts: 4596 Location: Picardie, France
Posted: Sun Jan 05, 2020 5:16 am Post subject: |
Good news it is working ! Please check Windows Task Manager and how many cores are available there ? If only 8 then it is propably BIOS limitation. _________________ Visit ABC CPU - Virtual CPU Museum. |
Joined: 21 Jul 2016 Posts: 3589 Location: Netherlands
Posted: Sun Jan 05, 2020 5:18 am Post subject: |
| Mixeur wrote: | | Mixeur wrote: | Windows 10 doesn't need anything.
I'm currently writing on the system with the ZS200800TCE25 from crazybubba installed. And despite what crazybubba said and what is written on cpu-world identification page, it is not a 12 cores but a 8 cores . And Windows identifies it as a 6128... |
Well, wait wait, CPU-World CPUID give me 12 cores !
http://www.cpu-world.com/cgi-bin/CPUID.pl?CPUID=69020 |
What does the windows task manager says? |
Posted: Sun Jan 05, 2020 5:49 am Post subject: |
Great ! 12 cores power from such a cheap CPU When you will be able to get better PSU please test stability with Prime95 Torture Test.
BIOS have an option to increase FSB ?
No hardware issues reported in Hardware Manager in Control Panel ? _________________ Visit ABC CPU - Virtual CPU Museum. |
Posted: Sun Jan 05, 2020 6:13 am Post subject: |
| Hmmm not bad result. Mine i3-8100 to compare but hey it is 7 years difference ! |
Posted: Sun Jan 05, 2020 7:03 am Post subject: |
This G34 board have only two memory channels and afaik it can be configured two ways: one channel per die or both channels for one die.
In latter case second die can access memory only through NUMA and it is much slower, it can cripple memory intensitive tests.
Obviously even the first configuration is slower than normal four channel system. |
Posted: Sun Jan 05, 2020 8:16 am Post subject: |
Yes. Common point of most of those motherboards is that there are very few memory slots (exit triple channel or quad channel), and are using cheaper chipsets than the one intended to be used with those cpus.
G34 motherboard is using RD890+SB700 instead of SR5670+SP5100. It is even faking CPU-Z on that point !
X79A motherboard is using a H61 instead of a X79. And so on... _________________ Register on x86-guide.net to manage and share your collection on-line !
Need to find a x86 ? Go to http://www.x86-guide.net ! Over 12000 chips listed ! |
