laptop cpu upgrade
Goto page Previous  1, 2
mavroxur
PostPosted: Sat Jan 23, 2021 8:55 pm    Post subject: Reply with quote
alehko wrote:
https://ibb.co/WDqPypG
Run it from within Windows again, but next time, right click the executable and select "run as administrator"
alehko
PostPosted: Sun Jan 24, 2021 1:50 pm    Post subject: Reply with quote
mavroxur,thanks for the advice, but unfortunately the program opens with this error https://ibb.co/TmQssmW
Calbris
PostPosted: Sun Jan 24, 2021 3:33 pm    Post subject: Re: laptop cpu upgrade Reply with quote
Something is wrong with the WinFlash utility, it's probably incompatible with Windows 10 for all I know.
Download Rufus 3.13 (https://rufus.ie/) and burn the .iso onto any USB flash drive that you have. Make sure that the partition scheme is selected as 'MBR' and the target system is selected as 'BIOS'.
The filesystem should be either FAT16 or FAT32 depending on your USB flash drive's capacity. As long as it doesn't use a fancy filesystem like NTFS or exFAT, it should work.
A small thought: is there an option in the BIOS that allows you to change the boot mode? If there is such an option, select 'Legacy BIOS' or anything similar to it. Don't select UEFI or UEFI+CSM, those won't work right with an ancient DOS update utility.
Once you're done with the BIOS update, and assuming that such an option exists in your BIOS, switch it back to whatever it was previously.
alehko
PostPosted: Mon Jan 25, 2021 1:54 am    Post subject: Reply with quote
Calbris,thanks for the help. Here is what I have in bioshttps://ibb.co/XbQ1Bjv
https://ibb.co/DCtTF5t
https://ibb.co/4VnyXZ0
Calbris
PostPosted: Mon Jan 25, 2021 7:05 am    Post subject: Re: laptop cpu upgrade Reply with quote
Looks like your Satellite U500 doesn't have an option for selecting UEFI or BIOS mode. Well, ignore it. I think you're fine as long as the 'Boot Speed' option isn't set to 'Fast'.
alehko
PostPosted: Mon Jan 25, 2021 7:22 am    Post subject: Reply with quote
Calbris,I have a hard drive ssd.I need to change the BIOS from "normal" to "fast"? Did I understand you correctly?
Calbris
PostPosted: Mon Jan 25, 2021 8:02 am    Post subject: Re: laptop cpu upgrade Reply with quote
No, don't. That will prevent you from booting into the USB flash drive.
You need to leave it as it is, as in don't change it.
alehko
PostPosted: Mon Jan 25, 2021 9:35 am    Post subject: Reply with quote
Calbris,ok i understand Very Happy
Page 2 of 2
