CPU Cooling
Goto page Previous  1, 2
FDIV
PostPosted: Mon Dec 18, 2006 3:31 pm    Post subject: Reply with quote
That is the fan that I am using. I purchased two (they were cheeeep on newegg.) The other is now in my gaming system. It moves enough air with that 120mm fan that I was able to disconnect the noisy 80mm fan in the side of the case and not have the passivly cooled raedon x800 graphics card overheat. Now my whole gaming system is now cooled by the 120mm cpu fan and a 140mm fan in the power supply. Though it is not as quiet as the home theater pc it is much better than it was and quite tolerable.
jd
PostPosted: Thu Dec 21, 2006 8:43 am    Post subject: Reply with quote
....I don't have the problem of fan noises bothering me like most...I guess I just got use to it.But my father built this really cool box below his desk he put the tower in. I'll try and get a pic...
It's made of simple 1/2" laminate boards to match the desk, sealed all the sides and top with special glue, leaving the bottom piece unsealed to remove the tower, and he cut out 2 vents for the air to flow threw.He also put some screen mesh (for screen doors) , at the vent holes to prevent bigger dust particals to come in.Well let me tell you, I can't hear a thing ! Very quiote ! And with the fans in the tower installed properly, 2 in front 2 in back, the airflow and temps are all cool in the summer !
I'm thinking of trying the same, but with a simple solution, foam boards !This should isolate the sound by alot !
JD
PostPosted: Fri Jan 05, 2007 2:22 pm    Post subject: Reply with quote
I decided to OC my system. From 3000+ 1,8 Ghz 200 MHz FSB I got 3800+ 2,4 GHz 267 MHz FSB. In Prime95 torture test I have max 78 degrees Shocked
I decided to buy Scythe too Wink Similar to JAC's Ninja - Infinity and OC more.
jd
PostPosted: Fri Jan 05, 2007 5:01 pm    Post subject: Reply with quote
I'm curious, which Scythe model did you get ?
JD
PostPosted: Fri Jan 05, 2007 5:03 pm    Post subject: Reply with quote
Hey JD,
Take a look here :
http://www.allegro.pl/item153157314__scythe_infinity_socket_754_939_940_am2_nowosc.html
jd
PostPosted: Fri Jan 05, 2007 5:07 pm    Post subject: Reply with quote
Aaaah yes !
I like that one !
jd
PostPosted: Fri Jan 05, 2007 5:10 pm    Post subject: Reply with quote
the one in my girlfriends tower , I just put in before Xmas, is this one by Zalman.
JD
PostPosted: Fri Jan 05, 2007 5:13 pm    Post subject: Reply with quote
Exactly. I read some reviews and propably it is well cooling system. I liked too Aerocool Dominator and Thermaltake SonicTower but i couldn't get supported version for AM2.
I remember old system on Athlon XP 2500+ Barton with Gigabyte 3D Rocket cooling. Very showy but not compatible with latest sockets and in tests had much worse performance/noice. I don't know if Gigabyte still produce cooling systems so good as was some time ago. I saw ASUS entered in this segment of market but nothing special what can predominate.
PostPosted: Fri Jan 05, 2007 5:15 pm    Post subject: Reply with quote
Yeah I thought about that Zalman too. At last Zalman is in acceptable price. This cooler is very well and in good price. Well choice.
jd
PostPosted: Fri Jan 05, 2007 5:17 pm    Post subject: Reply with quote
Actually that Zalman only cost her, in your dollars ------>59,90 € ,which is not bad price...to me anyway.
JD
jd
PostPosted: Fri Jan 05, 2007 5:19 pm    Post subject: Reply with quote
Remember these ? Very Happy
This are also a nice thing they came up with back then...
SocketA to P4 adapter
Adapter for s478 P4 MoBo so that a SocketA heatsink can be attached to it! With this you can also replase a broken s478 P4 heatsink assembly!
PostPosted: Fri Jan 05, 2007 5:22 pm    Post subject: Reply with quote
I didn't saw that thing here. Nice Smile
PostPosted: Fri Jan 05, 2007 5:42 pm    Post subject: Reply with quote
JD
You offered a nice flower to your girlfriend ! Wink
Page 2 of 2
