Biggest Collecting Mistake?
Goto page Previous  1, 2, 3
mister_rf
PostPosted: Tue Jun 07, 2016 4:01 pm    Post subject: Reply with quote
Both extruded polystyrene (XPS) and expanded polystyrene (EPS) are made from similar materials, the only difference XPS has a higher density as compared to EPS, due to the absence of air passages between its cells.
In generat the Volume Resistivity ohm-cm >10 exp16
To obtain a conducting polymer it needs to be doped with carbon particles (C). The color of Polystyrene Conductive Sheet is a black. Very Happy
PostPosted: Tue Jun 07, 2016 5:45 pm    Post subject: Reply with quote
Chook wrote:
Its relatively hard. I got it from Clark Rubber. Its not proper antistactic foam.
Thanks Justin
Want List
Trade List(Up-to-date)
Vlasta wrote:
RS Australia - it ain't cheap though
http://au.rs-online.com/web/p/esd-safe-foam-film-wrap/8153503/?origin=null|fp&cm_sp=featureproducts-_-FeaturedProductsContent-_-8153503
Thanks Steve
Want List
Kev Vader
PostPosted: Tue Jun 07, 2016 5:55 pm    Post subject: Reply with quote
I use non-slip matting, bought by the metre from Bunnings!
https://www.bunnings.com.au/matting-non-slip-magic-stop-90cm-black-2mag90bla_p6650115
Intel CPU's: 1400
Non-Intel CPU's: 222
Other: 200
RAM: Lots!
Page 3 of 3
