Posted: Thu Aug 24, 2006 9:57 am Post subject: |
| CPUShack wrote: | Lots of pretty K6's
That's one I'm always looking out for It's on my complete list but not the one I posted above (with the sheer number of part numbers available, it seemed to much tio add them as well for a new collector to worry about ) _________________ My graphics card database can be found at http://www.gpuzoo.com.
Posted: Thu Aug 24, 2006 10:02 am Post subject: |
| picur10 wrote: | What does embedded mean? Adn what is the meaing of the * or e.g. ALYD?  |
I think both questions ahve been asked before, and I don't know the answer. K6-200ALYD is a common part, but I've found nothing anywhere to say what the ALYTD means (in particular it's the "YD" that I wonder about...). The * is something I only know from this site and eBay, and I ahve no idea what, if anything, it means. Both are questions I'd like to answer on my website (now that I'm adding placeholders for known processors that I don't have, I will very soon also be adding extra info for all chips that I have, so this sort of info will be very helpful if significant and if known by anyone...) _________________ My graphics card database can be found at http://www.gpuzoo.com.
Posted: Thu Aug 24, 2006 10:04 am Post subject: |
| CPUShack wrote: | | Embedded K6 (used in switches etc) also happens to be an engineering sample |
Are they both ES? Did they only produce them as ES models? _________________ My graphics card database can be found at http://www.gpuzoo.com.
pinkie
Joined: 17 Sep 2005 Posts: 971 Location: Shenzhen,GD,China
Posted: Thu Aug 24, 2006 10:19 am Post subject: |
Is it a BGA package?
What size is it? smaller than a transmeta 5800?
Thanks,
Yan |
Posted: Thu Aug 24, 2006 11:03 pm Post subject: |
I was under the impression that they were, but vcould be wrong, what was their intended use? I think I have a pic of a similar one in a Cisco router. _________________ New for 2025! The CPU Shack has a co-processor!
Posted: Thu Oct 05, 2006 9:42 am Post subject: |
A few more part numbers to add to the list I previously posted in this thread:
K6 3D/233AFR
K6 3D/250AFR
K6 3D/333AFR
K6-2E+/350AUZ
K6-2E+/350IUZ
K6-2E+/400ITZ
K6-2E+/400ACR
K6-2E+/450ACR
K6-2E+/500ACR
K6-2E+/400ICR
K6-2E+/450ICR
Package:
A = 321-pin CPGA
I = 349-ball OBGA
Vcc:
C = 2.0V +/- 0.1V
T = 1.6V +/- 0.1V
U = 1.5V +/- 0.1V
Temp:
Z = 0 - 85
R = 0 - 70
I didn't add the K6-CA as I have no info other than that it exists (if anyone has one for sale, I'd be grateful to get one...) _________________ My graphics card database can be found at http://www.gpuzoo.com.
Root
Posted: Thu Oct 05, 2006 5:31 pm Post subject: |
info about K6-X markings:
Case Temperature
Q = 0°C–60°C
X = 0°C–65°C
R = 0°C–70°C
K = 0°C–80°C
Z = 0°C–85°C
Operating Voltage
T = 1.5 V–1.7 V (Core)/ 3.135 V–3.6 V (I/O)
P = 1.6 V–1.8 V (Core)/ 3.135 V–3.6 V (I/O)
N = 1.7 V–1.9 V (Core)/ 3.135 V–3.6 V (I/O)
M = 1.8 V–2.0 V (Core) / 3.135 V–3.6 V (I/O)
C = 1.9 V–2.1 V (Core)/ 3.135 V–3.6 V (I/O)
D = 2.0 V–2.2 V (Core) / 3.135 V–3.6 V (I/O)
F = 2.1 V–2.3 V (Core) / 3.135 V–3.6 V (I/O)
G = 2.2 V–2.4 V (Core) / 3.135 V–3.6 V (I/O)
H = 2.3 V – 2.5 V (Core) / 3.135 V–3.6 V (I/O)
Package Type
A = 321-pin CPGA
B = 360-pin CBGA
I = 349-ball OBGA
Also one can check http://www.amd.com/epd/processors/6.32bitproc/8.amdk6fami/index.html (embedded K6 family docs) _________________ FreeBSD - forever |
