CPU features identification program
Goto page Previous  1, 2, 3, 4, 5, 6, 7  Next
Post new topic   Reply to topic    CPU-World.com forums Forum Index -> News
PostPosted: Tue Jul 27, 2010 2:26 am    Post subject: Reply with quote
started adding Pentium sSpecs with the new template and it all working well Very Happy
and now i'm writing the chip information down & not relying on my memory of what chip I'm testing... so no need for you to fix my mistakes Laughing
have added the 75MHz P1s (desktop & mobile PGA) I have on hand & will slowly work my way thru the other speeds
PostPosted: Tue Jul 27, 2010 9:00 pm    Post subject: Reply with quote
CPU ID tab was added to some S-Spec pages. It looks very similar to CPU pages:
http://www.cpu-world.com/sspec/SU/SU081.html
I didn't add the tab to S-spec pages with ambiguous S-spec numbers, like Q136. I guess I can match by family name, but it doesn't affect many S-specs, so I decided to do it later.
It's possible that soon you will be able to edit them yourself. I had an idea how to link submitted CPUID info with nickname from the forum, if it works then I'll create a simple page where it'll be possible to edit submitted data.
PostPosted: Sat Dec 04, 2010 3:01 am    Post subject: Reply with quote
added Q135 & Q031 as the stepping info wasn't available on the site.
as I cant edit my submissions yet, you will need to fix up my typo Embarassed
listed part as A805260-120 for Q031 where it should be A8050260-120
but you may want to have the part A80502-120 used instead and put the marking in comments?
also with sSpec.. i used Q031 ES unlike the Q135 which is not marked with ES anywhere on the chip
PostPosted: Sat Dec 04, 2010 8:55 pm    Post subject: Reply with quote
I put A80502-120 as a part number for the Q031, and updated comment with A805260-120 part number. I removed "ES" from the stepping, otherwise it won't match Q031 stepping in the S-spec database, but added "Q031 ES" to the comment.
PostPosted: Wed May 25, 2011 7:44 am    Post subject: Reply with quote
just noticed that when I added QT69 I listed it as QT69ES so it doesn't link up to 80528PC1.XG0K page Embarassed
PostPosted: Wed May 25, 2011 1:35 pm    Post subject: Reply with quote
It wasn't displayed on the QT69 page because it was listed as QT96ES. I fixed it. It's ok to add S-Spec numbers with "ES" and "QS" at the end - those are automatically stripped.
PostPosted: Thu Jun 02, 2011 10:56 pm    Post subject: Reply with quote
The new "member area" thing ( http://www.cpu-world.com/sc/ ) now has a link to all CPUID submissions for the past three months. When you get to the list, you will be able to view your public CPUIDs, or edit them, even non-public ones.
PostPosted: Thu Jun 02, 2011 11:00 pm    Post subject: Reply with quote
great Smile
now I wont have to pester you to fix my typos Laughing
PostPosted: Thu Jun 02, 2011 11:23 pm    Post subject: Reply with quote
Neon_WA wrote:
great Smile
That was the idea behind implementing this feature Smile
PostPosted: Thu Dec 29, 2011 12:59 am    Post subject: Reply with quote
went to delete a double up CPUid but can't access my submissions
I checked my comment submissions.. and only some were listed under my id
Thinking about it.. even thou I'm signed into forum all the time.. only if I visit the forum first does it automatically input my forum id.
So many times when making a submission I type my id in.... but it seems even thou it is typed exactly the same.. it appears to consider it not the same.
Not a prob with comments.. these are made from machines in which I am permantly signed in on and will just make sure I visit forum first
but CPUid submissions are made from various test benches.. none of which are setup for browsing apart from submission program
PostPosted: Thu Dec 29, 2011 11:43 am    Post subject: Reply with quote
I can fix CPUID submissions if they were submitted with your forum nick. I will do after I get back.
PostPosted: Fri Dec 30, 2011 2:13 pm    Post subject: Reply with quote
CPUID submissions with your forum name were fixed. You should be able to see all of them now.
PostPosted: Fri Dec 30, 2011 6:37 pm    Post subject: Reply with quote
Yep.. all good now Smile
PostPosted: Tue Jan 24, 2012 10:34 am    Post subject: Reply with quote
just worked out why my CPUid info for QT69 doesn't link up automatically
I have the part number as 80528PC1.XGOK where it should be 80528PC1.XG0K
The submission is too old for me to correct
http://www.cpu-world.com/cgi-bin/CPUID.pl?CPUID=2880
PostPosted: Tue Jan 24, 2012 3:40 pm    Post subject: Reply with quote
I fixed it.
Post new topic   Reply to topic    CPU-World.com forums Forum Index -> News All times are GMT - 5 Hours
Page 5 of 7
