Help !! Upgrade Biostar M7VIZ
SteveM
PostPosted: Wed Sep 10, 2008 12:30 pm    Post subject: Help !! Upgrade Biostar M7VIZ Reply with quote
Looking for some help on what I can upgrade this motherboard to. I dont want anything too complex are technical to understand - looking basically for a plug and play upgrade. It presently has an Athlon 2500+ processor. Was wondering if the 3200+ was the fastest I could go to and will I be able to have plug and play install with it. Are there any other plug and play processors for it other than this possibility
Thanks !!!!!!!!!!!!!!!!!
Steve M
thomsonicus
PostPosted: Wed Sep 10, 2008 1:10 pm    Post subject: Reply with quote
biostar's cpu support pages claim that this motherboard supports processors up to FSB333 version of Athlon 3000+. You need to check what is the FSB (front side bus) when buying a new processor as there were verstions of 3000+ with FSB333 and FSB400. Also, don't forget to put the thermal compound between the processor and the radiator.
Power without the price.
SteveM
PostPosted: Sat Sep 13, 2008 9:01 pm    Post subject: Reply with quote
Yes, the FSB is 333 as you suspected. Ok, where can I go from here, what can I use
Thanks
Steve M
