Just got Core 2 Duo T7400 SL9SK from Ebay
Andrew
PostPosted: Sun Sep 28, 2008 12:50 am    Post subject: Just got Core 2 Duo T7400 SL9SK from Ebay Reply with quote
Hi, I posted earlier about cracked cpu from ebay.
I got a better one from the seller now. its still same T7400 SL9SK
My questions is..
On the back of the CPU, there are only 478pins, and at the corner of the CPU, 2 pins are missing. One of the missing spot has solder spot, and looks like a pin was pulled out (small hole on the solder spot). Is this normal?
I thought SL9SK is 479 pins. and SL9SE is 478.. Do you think previous user might have pulled a pin out to put it in the socket 478?
Thanks in Advance
PostPosted: Sun Sep 28, 2008 11:33 am    Post subject: Reply with quote
SL9SK is in 479-ball package. By the way, did you get your processor from this seller?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=150274923649
It looks like they soldered the SL9SK on the 478-pin adapter. I guess it will work like the SL9SE, except that the package is slightly thicker than real 478-pin package.
Andrew
PostPosted: Sun Sep 28, 2008 3:36 pm    Post subject: Reply with quote
yes similar seller from HK but different.
I just put it in my T60 it works great so far..
yes I find from other forum pulled out ball-cpus can get pinned.. but what do you mean by the package is thicker? acutal dimensions different?
Andrew
PostPosted: Sun Sep 28, 2008 3:55 pm    Post subject: Reply with quote
Ah, I get it.. about the adaptor that goes under..
but mine was not soldered to the adaptor. it looked like balls have been removed and individual pins were mounted in.
