Anas Guest
Posted: Thu Dec 04, 2008 3:36 pm Post subject: Motherboard Spec?? |
Hi guys, k i got this mobo that was donated to me - AOpen MK73LE-N... now ive looked up someplaces and ive concluded its almost impossible to find the specs of this borad, ive found some but they dont match the the specs on mine, so i was wondering if anyone knows a site or place i can get the full specs of this board, like the fsb and display card n all that
it came with a case and front audio/usb, it also came with a 1300mhz duron which i am now using. the board has a jumper which allows me to use either 100 - 124mhz or 124-166mhz, and ive tried to use my fake Athlon XP on it, which says its a 2600+ 133mhz but the multiplier is locked at 10.5 and it doesnt work at 166mhz so i ran it at 133mhz (1400mhz 1600+ xp) and it seemed to be fine in bios cuz thats how far i was able to get since i dont have extra harddrives laying around to boot it, oh and im using 128mb ram - Kingston Value Ram KVR-PC133/128-CR 740617059816. Also on all of the chips on the ram, the last number is -6, so i believe its 6ns ram campatible with 200mhz i think, so that shouldnt be a problem if i set the fsb to 166mhz.
k well lemme know if i missed out on anyinformation and if anyone has a site where i can the specs, thank you guys. |
Posted: Thu Dec 04, 2008 6:37 pm Post subject: |
Board's revision number needed.
Try to look for it on the net, as different revisions can have different features and other surprises. |
Cobracon
Posted: Thu Dec 04, 2008 7:24 pm Post subject: |
AOpen has a Download Center where you can get a copy of the owner's manual for your motherboard.
http://download.aopen.com.tw/ _________________ "Have you scanned the RAM timings for Operator's Headspace?? Too much real estate between the audio collectors will block the connection which allows proper operation of your computer."_Cobra
