KOB KT133 FSX - AXDA2600DKV3C?
Dudo5611
PostPosted: Thu Jan 08, 2009 3:45 pm    Post subject: KOB KT133 FSX - AXDA2600DKV3C? Reply with quote
Hi. Will the procesor AXDA2600DKV3C work on KOB KT133 FSX mainboard?
Thanks for your reply.
PostPosted: Mon Jan 19, 2009 4:01 am    Post subject: Reply with quote
first off, check whether it 133 or 133A chipset
from Mercury FAQ site
Quote:
Kindly ask you check KOB KT133a FSX can work with Athlon XP 1700+ with BIOS 3.6a (release 03/12/2002 , should be 3.6a) or not.
Please update BIOS 3.6a, and it can support to AMD athlon XP2200+ FSB133 .13u
check out this thread for some ideas if 133
http://www.cpu-world.com/forum/viewtopic.php?t=7314
and here for drivers
http://www.mercury-pc.com/product-detail.php?link=p-mainboards&subtitle=Mainboard&productid=69#
Dudo5611
PostPosted: Fri Jan 23, 2009 10:45 am    Post subject: Reply with quote
i have KOB KT133 FSX
I find this text in user`s manual in section Advenced BIOS Features Setup Option:
Quote:
External Cache Default: Enabled
Most processors that can be installed in this system use external (L2) cache memory to improve performance. The exceptions are older SEPP Celeron CPUs running at 266 or 300 MHz. Enable this item for all but these two processors.
and this in section Features:
Quote:
High-end Processors
Functioning as a platform for a high-end PC, the KOB KT133 FSX features a Socket 462 accommodating AMD Athlon processors that support 64/256 KB L2 OnChip cache and 100/200 MHz hostbus/core speed.
The KOB KT133 FSX supports 200 MHz frontside bus (FSB).
so processor AXDA2600DKV3C should work on this mainboard?
Thanks...
PostPosted: Fri Jan 23, 2009 11:59 am    Post subject: Reply with quote
Your manual sucks.
No need to treat us like free helpdesk.
Having some manners sometimes helps.
