Posted: Mon Jan 19, 2009 8:18 pm Post subject: Asus M2NC61S |
Hi all,
I am wanting to upgrade to the "best" processor my motherboard (Asus M2NC61S barebones) will support, which seems to be along the line of an AMD 5200. I currently have an athlon x2 4600+ 2.41 GHz. Would an upgrade make a noticeable difference or would I be better off getting another motherboard to support a faster processor?
Thanks |
Posted: Mon Jan 19, 2009 8:54 pm Post subject: |
Depends on what you do with your pc.
More ram is a good upgrade along with the cpu.
What's your operating system? |
Posted: Mon Jan 19, 2009 9:53 pm Post subject: |
| Vista, currently running 4 gig RAM. I do a little bitter of everything. Photo processing, gaming, video processing, office work, etc. |
Chiefish
Posted: Tue Jan 20, 2009 12:59 pm Post subject: |
Is it vista 32 bit or 64 bit, i thought only 64 bit will take advantage of 4 gigs of ram and 32 bit doesnt recognise it all. _________________ "The only reason for time is so that everything doesn't happen at once." A.E. |
Posted: Tue Jan 20, 2009 4:59 pm Post subject: |
| Don't know what the deal is. I installed 4 GB RAM and it is visible in the system info. Whether it uses all of it or not - I don't know. But I am using Vista Ulitimate 32 bit. |
