socketA upgrade
mvc
PostPosted: Sun Feb 08, 2009 4:14 pm    Post subject: socketA upgrade Reply with quote
hi folks!
my motherboard (asusA7V333) is equipped with an Athlon XP 2000+ (1667Mhz, Thoroughbred), i'dlike to cheap-upgrade the machine by throwing a XP3200+ into it.
Can anybody tell me if this is possible, or till which exact athlon cpu it is possible?
(Athlon XP Socket A(462); chipset: northbridge: via kt333 (100/133 fsb; 333 memory bus; southbridge via vt8233A)
thanks a lot
mvc
SonicSnif
PostPosted: Sun Feb 08, 2009 4:55 pm    Post subject: Reply with quote
depending on your board's exact revision, your board may already be close to its limit[1]:
rev 1.01 - up to 2600+ (266MHz Thoroughbred)
rev 2.0 - up to 3000+ (333MHz Barton)
[1] http://support.asus.com/cpusupport/cpu_support_right_master.aspx?type=1&name=A7V333&SLanguage=en-us
http://support.asus.com/cpusupport/cpusupport.aspx
cheers,
jon
mvc
PostPosted: Mon Feb 09, 2009 5:36 pm    Post subject: Reply with quote
thanks, problem solved
mine's revision 1.01
