Patrick.J
Posted: Thu Feb 26, 2009 2:26 am Post subject: Can someone help me plz... |
Just receive 2 processors, Intel Core2duo E7400 2.8GHz and an AMD Sempron 1250 2.2 GHz Socket AM2. Both are 64bit processor. Which one is best?? Which motherboard may i purchase to fit my processors. Have never work on 64bit , what the difference?? Can i get any feedback of someone plz..
Sorry for too much questions but i'm very new to his forum and to IT too.
Thanks all. _________________ Jp |
Joined: 04 Apr 2008 Posts: 3364 Location: Chicago, IL- US
Posted: Thu Feb 26, 2009 2:46 am Post subject: |
A BIG welcome to the best chip info site in the world, Patrick!
Most of the experts in my half of the world are sleeping, but someone should answer you soon.  |
Chiefish
Posted: Thu Feb 26, 2009 6:48 am Post subject: |
Without a doubt the E7400, there is no comparison really between the two. The mother board all depends on what you want to do with youre computer, SLI ect.... Youll need Windows 64 bit o/s to take advantage of the 64 bit tho. _________________ "The only reason for time is so that everything doesn't happen at once." A.E. |
Posted: Thu Feb 26, 2009 8:40 am Post subject: |
Thanks for your support.
May i install a windows 32bit?? compactible??
The pc will be specially for gaming.
Thanks for your interest. |
Chiefish
Posted: Thu Feb 26, 2009 9:09 am Post subject: |
Yes you can use 32 bit windows without any trouble at all. _________________ "The only reason for time is so that everything doesn't happen at once." A.E. |
Patrick.J
Posted: Fri Feb 27, 2009 2:57 am Post subject: |
Thanks!! I like this forum!! _________________ Jp |
