Xeon Engineering Sample DualProc with nonES?
sigmaxix
PostPosted: Tue Mar 31, 2009 2:16 pm    Post subject: Xeon Engineering Sample DualProc with nonES? Reply with quote
I ran across an Engineering Sample of a Xeon E5430 (QFTS), and was wondering if these are compatible with the standard (SLBBK) when running dual-processors? Or, will I have to buy another engineering sample?
Overclocking is not the concern in this case...
Wizzard1
PostPosted: Tue Mar 31, 2009 3:11 pm    Post subject: Reply with quote
Yes, one can mismatch similar processors... It doesnt matter ALL that much.
PostPosted: Tue Mar 31, 2009 3:31 pm    Post subject: Reply with quote
Awesome! Didn't want to mess with the thermal paste before making sure! Thank you.
PostPosted: Tue Mar 31, 2009 4:28 pm    Post subject: Reply with quote
It depends. Usually, sspec compatibility for DP or MP infos are written on spec updates.
But only for regular sspecs, not ES...
So, you can only try...
Wizzard1
PostPosted: Tue Mar 31, 2009 9:57 pm    Post subject: Reply with quote
Oh, and one thing to watch out for: ES are unqualified... They may have certain extra undocumented features, like bad multi-processor operations and extra sensitive thermal shutdown. But most are OK.
andamus
PostPosted: Wed Apr 01, 2009 2:45 am    Post subject: Reply with quote
My dual Xeon5405 ES runs fine, I only needed to put the latest bios from my motherboard vendor.
