Please help with CPU upgrade..
PostPosted: Mon Apr 13, 2009 3:42 pm    Post subject: Please help with CPU upgrade.. Reply with quote
Hi, ill just get right to th ebasics. My motehrboard is a A8M2N-LA (NodusM3) with Phoenix Systems 3.07 Bios. It came with a AMD 4200 but i wanted to upgrade it to a 5600. I plugged everything in correctly and hooked up the computer. However, when i turn it on i hear the fans and everything but the screen is blanc, and i hear a repetative, long beep sound. I installed the old cpu (using it now) and everything booted fine. Can anyone explain to me why it is not booting up with the 5600 cpu and making a beep sound every 2 or so seconds? Thanks! Crying or Very sad
Cobracon
PostPosted: Mon Apr 13, 2009 5:06 pm    Post subject: Reply with quote
If this link is the one for your computer/motherboard, it states that support is provided for up to an Athlon 64 x2 5000+:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00714578&dlc=en&lc=en&cc=us
yuriy101
PostPosted: Mon Apr 13, 2009 6:35 pm    Post subject: Reply with quote
Ive read that before and i contacted HP support. They said it should still work with the Phoenix 3.07 bios which i have..Guess ill have to sell the cpu Sad
PostPosted: Mon Apr 13, 2009 8:10 pm    Post subject: Reply with quote
5600+ should be supported:
http://www.cpu-upgrade.com/mb-ASUS/A8M2N-LA.html
One poster wrote on that page:
Quote:
I just received an AMD Athlon 64 x2 5800+ from Newegg today and installed in an older HP a1268c under bios version 3.07. Works fine so far, had a couple no post beep errors at first but they worked themselves out with a few restarts and adjustments (for some reason it was beeping faulty memory on good ram).
PostPosted: Tue Apr 14, 2009 10:05 am    Post subject: Reply with quote
Thats exactly what happens to mine, the beeps indicate that the ram is faulty or not there at all. Howeverm when i hooked up my old cpu it worked fine! Is there any way to fix this? Thanks to all for trying to help.
yuriy101
PostPosted: Tue Apr 14, 2009 7:10 pm    Post subject: Reply with quote
I also contacted HP for support, they said its something with the ram. They told me to take out the ram for 2 minutes and put it back in, i will do it friday (the only time i actually have some spare time) and report back. Untill now, thanks for all help and please post any other peices of info, its all greatly appreciated! Smile
