Exraided Guest
Posted: Wed Apr 29, 2009 12:46 pm Post subject: UPGRADING AN AMD ATHLON XP 2000+ FOR GAMING SUGGESTION? |
Hi, In your opinion what would be the best choice of upgrade for my AMD Athlon XP, 1666 MHz (12.5x 133) 2000+ Thoroughbred-B, Motherboard is an Asus A7N8X v2.0 Deluxe Socket 462 (Socket A) Supports FSB200 up to 400.
Was looking for a good CPU for gaming and such. Another noob question am I limited to what model of CPU to upgrade example since my CPU is a Thoroughbred will I be able to upgrade to say a .... Barton, or a Thorton? Thank you.[/b] |
Posted: Wed Apr 29, 2009 2:07 pm Post subject: |
Well all of the socket A desktop processors should be supported by that board, if it has a recent BIOS. You can check here to confirm:
http://www.cpu-upgrade.com/mb-ASUS/A7N8X_Deluxe.html
Which to get? If you need/want the best, then Athlon XP 3200+ (Barton) - know that there is a significant price premium for this one, because it is the fastest in its class.
Think hard about spending much money on a system that is 2 generations ago (K7). Depending on your circumstances, it may be more cost effective to save up for a current generation system. It depends on how hard you game, and what resources you have. If you proceed to upgrade this board, then perhaps consider the Athlon XP 2800+ or 3000+ (both Bartons), which are less costly, but nearly as fast. |
Exraided Guest
Posted: Wed Apr 29, 2009 2:50 pm Post subject: Thank you so much! |
| THANK YOU SO MUCH FOR THE INFO! YOU'VE SAVED ME THE STRESS AND HEADACHES OF MAKING ANY FUTURE BAD PURCHASES! AGAIN THX! |
