gibsones335
Posted: Thu Sep 17, 2009 9:56 am Post subject: Need Help Identifying Core 2 Duo Mobile ES CPU's |
I have come across several Core 2 Duo Mobile CPU's that I am having difficulty in identifying them. Any help would be greatly appreciated.
I have looked through the CPU World S-Spec database, and found several numbers that are close, but not exact.
They are marked as follows:
LE80537
C626A170 QRSE ES
Another hint - the Intel copyright at the bottom of the chip has an '05 date.
Also, are there any desktop or micro ATX motherboards that is compatible with this CPU?
Thanks in advance. |
Wizzard1
gibsones335
Posted: Thu Sep 17, 2009 11:17 am Post subject: |
| Thanks Wizzard1, That is very helpful. |
gibsones335
Posted: Thu Sep 17, 2009 11:19 am Post subject: |
Wizard1, another question for you -
If I buy a motherboard that is compatible with this CPU, will one of the CPU identification utilities (CPU-Z, etc) indicate the "production equivalent" of the "engineering sample"?
Thanks, |
Posted: Thu Sep 17, 2009 12:26 pm Post subject: Re: Need Help Identifying Core 2 Duo Mobile ES CPU's |
| gibsones335 wrote: | LE80537
C626A170 QRSE ES |
Core 2 Duo Mobile L7200 1.33 GHz / 667 MHz / 4 MB
Wizzard1
Posted: Fri Sep 18, 2009 9:01 am Post subject: |
Thats a nice low power processor  |
