Cyrix Production code help
PostPosted: Mon Mar 07, 2005 12:50 am    Post subject: Cyrix Production code help Reply with quote
I've about completed the MediGX page.
Now I need to redo the Cyrix one.
Heres what I need
Model (front):
Production code (back):
Especially important are black top and grey top.
as well as low (100) speed and high(366) speed chips
I know its alot of work but I need more records to tell
whats up. It looks like some of these may have been made without a liscense to do so.
There is alot of neat ino here for sure.
Thanks in advance
John
PostPosted: Mon Mar 07, 2005 12:54 am    Post subject: Reply with quote
oh and if it has resistors on top
or a gold bottom I wnt to know
PostPosted: Mon Mar 07, 2005 1:14 am    Post subject: Reply with quote
Here is what we are getting at
(look at the bottom of the page)
http://www.cpushack.net/CyrixID.html
note the special ones
small print
black
grey
es
LV etc
Thanks
Borris70
PostPosted: Mon Mar 07, 2005 12:58 pm    Post subject: Reply with quote
Cyrix MII-333GP (black lid) 3LGEM913XJ
Cyrix MII-300GP (black lid) 3LGEM851YP
best regards borris
++ cpu-sammlung.de ++
PostPosted: Mon Mar 07, 2005 5:49 pm    Post subject: Reply with quote
awesome, thanks for those who have gotten me codes
I also can use ST 6x86 codes.
the SHOULD start with G8L or G9L
PostPosted: Tue Mar 08, 2005 12:48 am    Post subject: Reply with quote
Much thanks to morkok, who prvided a TON of raw data.
The Cyrix ID guidehas been completely redone.
See what you think.
Thanks for everyones help. Smile
Simmayor
PostPosted: Sat Apr 09, 2005 2:50 pm    Post subject: Reply with quote
I have traded a Cyrix MII-300GP Silver top. It's from China so it could be a fake.
The code is : VASR7912AB
I could not decifer the code, can you help me?
Simmayor
PostPosted: Sat Apr 09, 2005 4:05 pm    Post subject: Reply with quote
Its a new code
but I can tell you this.
Made by national semiconductor
Week 12 1999
.18u Should be 2.2V (first revision)
AB is the die run code
Made is South Portland, Maine
Assembled in Singapore
R7 is the Lot number.
Looks to be legit to me.
PostPosted: Sun Nov 30, 2008 10:56 pm    Post subject: Reply with quote
thx was really helpful Very Happy Very Happy
PostPosted: Mon Dec 01, 2008 12:44 am    Post subject: Reply with quote
John,
I have these, if you still need this info:
MII Gold 300, 66 (resistors) V7SH7901AF
MII Gold 333, 83 ( " ) V7SJ2845FB
6x86 Gold 166, 133 ( " ) GAKJ3707C
ST 6x86 Gold 166, 133 ( " ) AB70L9886E
Do you need any IBM CPU info?
PostPosted: Mon Dec 01, 2008 2:24 am    Post subject: Reply with quote
Dont need IBMs for now
