cpu upgrade successful, or was it?
noname
PostPosted: Thu Jan 07, 2010 10:33 pm    Post subject: cpu upgrade successful, or was it? Reply with quote
1.3ghz amd duron (13x100)
1.25gb sd ram (133)
nvidia geforce 7600gt(570/700)
gigabyte ga-7zx rev.1.x motherboard
just bought a athlon xp 2400 n put it in for the little upgrade from 64kb to 256kn cashe n 200mhz increase. its running at 1500mhz since my mobo doesnt support 133mhz fsb, booted loaded windows played a few games everything is cool Smile
but on boot up, it shows my chip as athlon xp 1050mhz but in windows it shows 1.5ghz, cpu z and pc wizard 2010 show what the initial rating should be and what they are they both show 1.5ghz, my games run a bit better so it seems to be working.
but is it actually at 1.5ghz? or am i just fooling my self cuz im to excited?
Chook
PostPosted: Fri Jan 08, 2010 4:32 am    Post subject: Reply with quote
The bios has a bad habit of showing the incorrect speed if it doesn't support the cpu properly. But it usually works anyway so I'd say it is running at 1500.
General failure reading disk in drive A
Who's General Failure and why is he reading my disk?
PostPosted: Fri Jan 08, 2010 4:47 am    Post subject: Reply with quote
Please tell us your motherboard model.
PostPosted: Fri Jan 08, 2010 7:12 am    Post subject: Reply with quote
he mentioned it in the 1st post + "100 mhz fsb only".
Psst. here it is: http: //www .gigabyte. com. tw/Products/Motherboard/Products_Spec.aspx?ProductID=1316
Too much 4004 dreaming makes you tired in the morning Smile LOL
Smile Yeah! Yeah! Yeah!
(it's just joking time)
So man, you could achieve FSB 133 by overclocking.
The GB bios usually shows other modified fequencies when you overclock the fsb, as they have fixed ratios.
Problem with overclocking with fixed ratios is to burn some components not ment to work at higher rates of frequency.
Just be extra careful.
PostPosted: Sat Jan 09, 2010 1:54 am    Post subject: Reply with quote
ok thank you Smile
