Best 2.8ghz P4 (478 pin/512 cache/533 FSB) CPU ???
clandestine
PostPosted: Thu Jan 14, 2010 2:18 am    Post subject: Best 2.8ghz P4 (478 pin/512 cache/533 FSB) CPU ??? Reply with quote
im looking for a 2.8ghz cpu (478 pin) and id like to know which sspec code i should pursue... any pointers? The intel sspec finder seems to be lacking some or a very large amount of ppl are making up the sspec code on the cpus they're sellin. If you have the knowledge I think there is a 3.06ghz compatible with the board i'm working with (Intel D845PEBT2); but that seems to be more of a mess as far as finding the one i would want... it'd have to follow the same guidelines 478 pin/512cache/533 FSB/.13 micron
Thanks to anyone who can point me in the right direction... Confused
View user's profile Send private message   AIM Address Yahoo Messenger
PostPosted: Thu Jan 14, 2010 2:42 am    Post subject: Reply with quote
going by the intel site
http://www.intel.com/support/motherboards/desktop/D845PEBT2/sb/cs-012857.htm
you can use a 3.06GHz northwood cored processor
http://www.cpu-world.com/CPUs/Pentium_4/Intel-Pentium%204%203.06%20GHz%20-%20RK80532PE083512%20(BX80532PE3066D).html
and SL6PG & SL6QC are both D1 stepping (newer stepping)
if you wanted a 2.8GHZ.. then SL6PF or SL6QB are the lastest steppings
http://www.cpu-world.com/CPUs/Pentium_4/Intel-Pentium%204%202.8%20GHz%20-%20RK80532PE072512%20(BX80532PE2800D).html
EDIT >> had a look at the P4 spec update... and there is little difference between C1 & D1 stepping Northwoods.... so any of the sSpecs listed on each of the processor pages will be good Very Happy
