Confused about Latency?
Post new topic   Reply to topic    CPU-World.com forums Forum Index -> Memory, peripheral and other chips
Marge010
PostPosted: Sat Jan 30, 2010 11:57 am    Post subject: Confused about Latency? Reply with quote
I want to upgrade my current 1gig DDR-400 (2x512mb single channel) to 2gigs (1Gb x 2 Dual Channel) but I'm confused about the timings coz there are some brands having 3-3-3 or 3-2-2 latencies (Kingston & Crucial) but my mobo can accept a 3-4-4-8 latency at 200mhz. Now, my question is: Can I use other memory modules with different timings other than what my mobo accepts as long as it has a CL-3 spec?? I am afraid it might be incompatible with my board (AsRock ConRoe 865GV). I don't want to waste extra cost especially DDR modules nowadays cost much. Please help. Thanks...
nessus550
PostPosted: Sat Jan 30, 2010 12:01 pm    Post subject: Reply with quote
Hello, buy the less expensive, the difference in real usage is very small.
Regards
PostPosted: Sat Jan 30, 2010 3:44 pm    Post subject: Reply with quote
Regards
I'd add, from very small to non-existent.
Unless you have applications that need the lowest latencies it makes no difference.
As nessus says, buy the less expensive and be happy Smile
PostPosted: Tue May 04, 2010 2:12 pm    Post subject: Reply with quote
In terms of network, latency is defined as expression of how much time it takes for a packet of data to get from one designated point to another or it is a synonymn of delay.
Tetrium
PostPosted: Tue May 04, 2010 2:50 pm    Post subject: Reply with quote
Weren't we talking about RAM latencies earlier?
Anyway, in the end it's up to you if you how much money you're willing to spend on your rig but as posted before, differences should be measurable only, you'll notice nothing if hardly anything using CL2 instead of CL3
Post new topic   Reply to topic    CPU-World.com forums Forum Index -> Memory, peripheral and other chips All times are GMT - 5 Hours
